20 Most Recent RCA RCU600WMS Remote Control Questions & Answers
Code for a Panasonic TV/VCR
Hello, Urpurdy - Am I safe to assume you have the user manual (in printed / paper format) for the RCA RCU600WMS remote control? If you do not, you can find it and download and save the PDF document here: https://voxxintl.zendesk.com/hc/en-us/articles/225306867-Information-User-Manual-and-Code-List-for-the-RCA-RCU600WMS-Universal-Remote-Control . You can then print it from the saved document. Tip: I suggest you set up a file folder in your computer Documents folder, titled: RCA TV Remote (or something like it, so you can find it whenever you may need it.) Also, I print the user manual out and keep it near the TV for future reference. The user manual includes the programming instructions and code lists starting on page 6 (PDF page 4). Best wishes.
12/17/2017 7:29:27 PM • RCA RCU600WMS... • Answered on Dec 17, 2017
0answers
Codes
Be the first to answer 11/28/2011 6:28:59 PM • RCA RCU600WMS... • Posted on Nov 28, 2011Be the first to answer
I cant turn the tv off or on, but i change change
I know the website you need--click the link at the end of my answer, then select your model # (RCU600WMS) from the drop-down menu...you'll find codes/manual for any TV you try it with! >>CLICK HERE
5/5/2011 6:23:58 AM • RCA RCU600WMS... • Answered on May 05, 2011
I cannot program program this
http://www.retrevo.com/support/RCA-RCU600WMS-Universal-Remotes-manual/id/402dj594/t/2/ provides a downloadable manual for your remote.
The TV codes for a Sharp TV are 173, 095, 171, 004, 006, 012, 029, 111, 112, 113, 12 in case a "Code Search" from your remote doesn't extract and/or store the codes.
Hope this helps.
2/22/2011 6:54:37 AM • RCA RCU600WMS... • Answered on Feb 22, 2011
Need tv code for olivia
Please try by searching at this link:
http://remotefinder.rca.com/default.aspx?site=rca
2/21/2011 2:10:55 AM • RCA RCU600WMS... • Answered on Feb 21, 2011
Mi problema es que yo compre el control remoto que
el problema de los controles universales es que casi no funcionan con los dvd´s y cuando lo hacen hay que buscar que tecla hace cual funcion le recomiendo que busque un original
12/9/2009 7:06:58 PM • RCA RCU600WMS... • Answered on Dec 09, 2009
RCU600m TV vol control
RCA has a site for their remotes, look here for codes:
3/27/2008 8:09:27 AM • RCA RCU600WMS... • Answered on Mar 27, 2008
RCA 4 DEVICE UNIVERSAL REMOTE, NEED 5 DIGIT CODE FOR DVP 3150V VCR DVD COMBO.
Please don't type is all CAPS, it is considered SHOUTING and is harder to read. Thanks. No one buys Universal Remotes, you buy a remote made for the device, a copy of the original. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.com > itm Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Type: Remote Control ; Manufacturer Warranty: None ; Custom Bundle: No ; Color: Gray ; Model: Philips. MPN: DVD740VR99 DVD74DVR, DVD740 DV... Compatible Brand: For Philips Compatible Model: DVP3150V/37 US$49.91 · ‎In stock
3/11/2023 12:07:47 AM • RCA Televison &... • Answered on Mar 11, 2023
My Roku flat screen tv the original remote broke so I bought a RCA 3 universal remote and I can't get it to connect
Question edited for clarity. It is a 'Roku', not a 'ruko'. Roku is a streaming service and not a television manufacturer. The put their badge on a television made by an established maker that also has their streaming service built in, or with a set top/side dongle. https://www.roku.com/en-ca/products/roku-tv https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote You buy the remote SPECIFICALLY for the television you own. That is done by the model number. https://www.google.com/search?q=roku+television+replacement+remote ..
3/10/2023 12:51:10 AM • RCA Televison &... • Answered on Mar 10, 2023
What is the code for a naxa DVD player ND-861
To program your RCA universal remote to control your Naxa DVD player ND-861, you will need to use the correct code for your device. Here are the steps to follow:
Power on your Naxa DVD player.
Press and hold the "Code Search" button on your RCA universal remote until the indicator light turns on.
Release the "Code Search" button.
Press and release the "DVD" button on your RCA remote.
Enter the code for your Naxa DVD player. You can find a list of RCA remote codes for Naxa DVD players in the RCA remote manual that came with your remote or by searching online. For example, the code for Naxa DVD players may be 3394.
Press the "Enter" button on your RCA remote. The indicator light on your remote will turn off if the code was entered correctly.
Test the remote to see if it's working. Try playing a DVD and using the remote to navigate the menu.
If the first code you tried didn't work, repeat the steps with a different code until you find one that works. If none of the codes work, it's possible that your RCA universal remote is not compatible with your Naxa DVD player.
3/6/2023 11:09:32 PM • RCA Televison &... • Answered on Mar 06, 2023
2answers
Having trouble with RCA tv vertical and horizontal lines can you help?
Generally horizontal lines are caused by a bad panel, there are COF IC's that give issues a lot of time and they aren't replacable.
3/6/2023 11:06:17 PM • RCA Televison &... • Answered on Mar 06, 2023
My Kef psw2000 power on but but no sound,when i plug in RCA cable standby turn on,I think it's IC,pls what are the IC number for Kef psw2000
First off, even with the IC numbers are you going to be able to replace the faulty parts, in most cases it's not something that can be done without a soldering station, plus hot air station and advanced soldering skills, it's not like soldering a couple wires together. If you're able to replace them take the numbers off the top of the chips and cross reference them.
3/6/2023 10:54:09 PM • RCA Televison &... • Answered on Mar 06, 2023
2answers
Rca rlded5098-b-uhd Backlight control
The actual LED strips have failed, chances of it being a board issue are slim, replace the backlights and all will be well
2/28/2023 9:50:02 PM • RCA Televison &... • Answered on Feb 28, 2023
Rca wont turn on what do i do I tried every thing but it won't turn on
If your RCA TV won't turn on, there are a few things you can try:
  1. Check the power source: Make sure that the TV is properly plugged in and the outlet is functioning properly. You can also try plugging in a different device to the same outlet to see if it works.
  2. Check the power cord: Check the power cord for any damage or fraying. If you see any damage, try replacing the power cord.
  3. Try a different remote: If you are using a remote to turn on the TV, try using a different remote or try turning it on manually using the power button on the TV.
  4. Check for any error messages: If the TV is showing an error message or blinking lights, refer to the user manual or contact the manufacturer for troubleshooting steps.
  5. Reset the TV: Unplug the TV from the power source for at least 30 seconds, then plug it back in and try turning it on again.
If none of these steps work, it may be a more serious issue that requires professional repair.
2/26/2023 6:13:15 AM • RCA Televison &... • Answered on Feb 26, 2023
RCA LCD TV Model #39LB45RQ; Power Board #RE46DZ1751. No standby light; ~2.4v measured at the 5v standby pin. Is there any specific component on the board to further test/replace?
There are a few components that could be responsible for the lack of standby power on the RCA power board:
  1. Fuse: Check to see if the fuse on the power board is intact. If it's blown, then that could be the reason for the lack of standby power.
  2. Capacitors: Check the capacitors on the power board for signs of bulging or leaking. If any of the capacitors are faulty, then they may need to be replaced.
  3. Diodes: Check the diodes on the power board to ensure that they are not shorted or open. If any of the diodes are faulty, then they may need to be replaced.
  4. Voltage regulator: Check the voltage regulator on the power board to ensure that it is providing the correct output voltage. If the voltage regulator is faulty, then it may need to be replaced.
If all of these components check out, then it's possible that the power board itself is faulty and needs to be replaced.
2/26/2023 5:23:39 AM • RCA Televison &... • Answered on Feb 26, 2023
I have a RCA dvd home theatre system rtd317 & the tray opens & closes with or without a disk & won't read the disk.
If your RCA DVD home theatre system RTD317 tray is opening and closing without reading the disk, and you've tried unplugging it, cleaning the laser lens, and the motor doesn't seem to be working, it's possible that there may be an issue with the motor or with the disk mechanism itself. Here are a few troubleshooting steps you can try:
  1. Check the disk: Make sure that the disk you are trying to play is clean and free of scratches. Sometimes a dirty or scratched disk can prevent the player from reading it.
  2. Reset the system: Try resetting the system to its default settings. To do this, unplug the unit from the power source for a few minutes, then plug it back in and turn it on.
  3. Check the motor: When the tray closes, listen closely to see if you can hear the motor spinning. If you can't hear the motor, there may be an issue with the motor or with the power supply to the motor. In this case, it may be necessary to have the motor replaced.
  4. Check the disk mechanism: If the motor is working but the disk still won't spin, there may be an issue with the disk mechanism itself. In this case, it may be necessary to have the disk mechanism repaired or replaced.
  5. Contact customer support: If none of these steps work, it may be best to contact the manufacturer's customer support for further assistance or to have the unit repaired by a professional.
Remember to always follow the manufacturer's instructions and safety guidelines when working with electronic devices.
2/24/2023 1:32:20 PM • RCA Televison &... • Answered on Feb 24, 2023
RCA LED 50B45RQ tv turns on, lights up screen, but screen is solid blue.
It sounds like you may have an issue with the backlight of your TV. If a backlight is not getting adequate power, it can cause the screen to appear blue or have "flashing white splotches". The best way to resolve this issue is to have a qualified technician inspect the TV to determine if there are any issues with the backlight power supply. If there is an issue with the power supply, they will be able to replace it and resolve the issue.
2/22/2023 7:12:07 PM • RCA Televison &... • Answered on Feb 22, 2023
2answers
Need a schematic for RCA RT2870R surround sound 5.1 receiver.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://schematicscom.blogspot.com/ http://homenol.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
2/21/2023 11:11:11 PM • RCA Televison &... • Answered on Feb 21, 2023
RCA RCU600WMS Remote Control Logo
Popular Tags
11 questions posted
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
code panasonic tv vcr
  • Televison & Video
