20 Most Recent
RCA RT2250 System Questions & Answers
Rca rt2250 no sound
please give us more details, I don't know what reciever you want to use? AM,FM? or some other devices.
but if it's the am,fm reciever well you can find it in your instructions manual how to set it though.
just follow the steps and you will have it..
have a nice tunning
just don't rate me badly^^
ps:
make sure your antenna is connected properly..
Power but no sound
hook up the antenna at the back and try to tune-in to your favorite radio station.
read the description at the back of your rca rt2250, how to connect your antenna.
connect it properly and raise up the antenna, put it where the signal is good.
Rt2250 rt2500 speaker static noise hum buzz until fully warmed up
It sounds like a capacitor in the power supply is just about to die. With the power disconnected have a look at the large tin can looking gizmos near the power transformer. There could be a couple of them. Leave the unit switched off for a while before going near them they could still pack a splat. Replace them with the same value and make sure they're connected the right way and it should solve your problem.
Whilst in there have a good look for any other smaller capacitors which look as if they're getting rounded at the top. Replace them too.
Either that or dig deep and buy a new one.
My sound keeps cutting in and out what do i do?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
There is a problem with one or both of the audio amp
circuits. The amp is going into a protect mode as to protect and save your
speakers. Sorry but there is no simple fix. this will need to go to the skilled personnel who specialized on it to
be diagnoised. Good Luck
Only VCR2 sound working, no video
if you want you can bypass the video instead of plugging it on your system feed it directly to your tv., you only need the white and red cables for your audio to work, red for right channel and white for left channel the yellow one is for video, you can directly plug it on your tv
