20 Most Recent
RCA RTD155 System Questions & Answers
Rtd 155 stuck in standby mode
Possibly the power supply was damaged but could as simple as a blown fuse due to a possible "surge" when the power came back on!
I lost original RCA RTD155
I would recommend getting a Logitech Harmony remote. The benefit of this universal remote is that you can program macros to start all of your devices in whatever order you want them to turn on so you can have programs like "Watch DVD or Watch TV", the remote will switch your TV to the appropriate input and output channels.
The other good thing about this remote is that you can program buttons specific to your device. You simply plug this into your computer and type in your model number and it loads all of the codes automatically. The RTD155 is supported by the Harmony series.
Read more about them here:
http://www.logitech.com/en-us/remotes/universal-remotes
Rca rtd155 dvd player continues to read no disc
Try to play a CD audio. If it plays OK then the video laser is bad in the player. If it doesn't play, open the player and inspect the lens for dust and clean carefully with a "Q" tip with alcohol. If these remedies don't work, then replace the drive.
We need a new remote
If you want original remote you have to go to RCA you should be able to order it from there web site
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv. I’m happy to help further over the phone at
https://www.6ya.com/expert/brandon_60dfebff379d64bd
11/23/2008 12:44:47 PM •
RCA RTD155...
Answered
on Nov 23, 2008
