20 Most Recent Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS CONTROLLER (PELPL2050) Questions & Answers
no may ne u need config it manually
Pelican PL-2050... | Answered on Jun 25, 2010
hira895
In regards to your wireless connection issue with your XBOX 360 do you have the wireless adaper connected to the XBOX. Note most XBOX 360's do not have a built in wireless adapter, some of the Elites do but most do not.
Hope this helps
Issken
Pelican PL-2050... | Answered on Nov 07, 2009
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Pelican PL-2050... | Answered on Aug 06, 2009
Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
Pelican PL-2050... | Answered on Apr 10, 2009
Yes it can. My friend is using it.
Pelican Video... | Answered on May 14, 2017
Video Game Consoles & Games Logo
Popular Tags
13 questions posted
Top Pelican Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Pelican Video Game Consoles & Games
Most Popular Question
old xbox system wireless
  • Video Game Consoles & Games
