20 Most Recent
RCA RS2640 CD Shelf System Questions & Answers
CD player just says READ on it
Buy a CD cleaning kit, this will clean the plastic laser lens that is hard to get at, hopefully this will clean any dirt on the lens and bring it back to operational mode.
Where is fuse located
Remove the back panel of the unit. If the fuse replacement blows again as soon as you turn the unit back on, you might have to troubleshoot the power supply. Good luck Mike!
How to hook an ipod to a rs2640
This one is fairly easy for you! Go to Radio Shack or similar place and get a cable that has an !/8" (3.5m? they may call it) Male, (which is what your I-Pod should use, double check this when you go look at them...some I-Pods use 3/32"), then at the other end you need what they call RCA ends....plug the RCA's into the front AUX IN jacks, plug the other into your I-Pod, set your stereo to AUX and enjoy!
CD player skips. How do I get at it to clean it?
I hope I'm not too late!! It is easy to pull the cover off of the little guy.there are (6) screws on each side. and I think (1) on the back. NOTE where they came from...there are LONG, MED., and SHORT ones......it is easy, just take a little piece of paper and note where they came from. Once you have the screws out, just sort of lift it offby GENTLY puuling the tads from under the front face plate.Then take a Q-tip and clean the pick up lense. (It looks like a tiny class eye sort of). I've done this to mine several times. It sounds difficult, but once you get at it, you'll find it IS easy!!
Strange buzzing noise
Sounds like a bad filter cap in the power supply.when you change dimmer switch the buzz changes slightly because of a different power sraw on the power supply. If you are not versed in electronic repair. Get an Estimate. Or if unit is old get yourself a new one. Good Luck
I need a manual for this system as i have lost
You can download the complete instruction manual in PDF format by clicking this
link.
On the page which opens, click on the "
Download" button to download and save the manual.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
How do I set the clock?
HelloTo set clock do the folloing:[1] Press and hold 'clock' until the hour flashes on the display.[2] Press 'digital tuning' << or >> to set the hour and then press 'clock' to shift to minute digits.[3] Press 'digital tuning' << or >> to set the minute.[4] Press "PROG.SET" to save the setting and "STOP" to quit setting.Note: When ths system is ON you can press clock to display the current time for about 2 seconds.. OKWish You A Happy and Prosperous 201.Gopakumar G, Trivandrum City, Kerala State, South India.
