20 Most Recent Samsung 4 CHANNEL DIGITAL VIDEO RECORDER EZ-DRIVE4 ***120fps Live&30fps Record*** Questions & Answers
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Samsung 4... • Answered on Jul 13, 2007
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box.
Samsung... • Answered 9 hours ago
Disconnect from mains supply for 15 minutes and reconnect. If there is still no live feed, contact your feed people, satellite, cable, IPTV company.
Samsung... • Answered on Jun 09, 2021
The problem is that you are not a television engineer. This explains the issues that you are facing and that we see 60 times a week here on Fixya. https://www.fixya.com/support/r29790007-repairing_own_television ..
Samsung... • Answered on Jun 08, 2021
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Samsung... • Answered on Jun 07, 2021
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the right column of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/
The issue you are describing sounds like the the LED back lights are drawing too much current and the power supply is going into a protection state. When the clicking happens the current drops and the power supply comes on and the LED lights try to come on and the process repeats. It could be an issue with power supply but the only available item from a supplier I recommend is the back light strips and the entire set is about 160 dollars. Big screen units are not easy to service as they take a lot of space. If you are not versed in electronics, I dont recommend that you try to repair it yourself. usd.
Samsung... • Answered on Jun 01, 2021
That is an issue I have never seen on here before, and I have seen thousands. It leads me to think it is a remote control issue, or if it is cycling on and off, on, and off every few seconds, the power board. Two things to try. Remove the mains plug to the television. Remove the batteries from the remote. Leave 10 minutes, and put brand new Duracell batteries in the remote. Plug in the television and try again. Remove the wall plug for 5 minutes. Plug it in. What happens if you switch on and change channels and volume from the set, NOT from the remote. If it works okay, it is the remote or the remote sensor in the television. My usual advice is here https://www.fixya.com/support/r29790007-repairing_own_television ..
Could be back up cell flat.
Samsung... • Answered on May 29, 2021
It depends if you are a Digital Light Processing engineer? LCD and DLP are two new and different imaging technologies for flat screen TVs. LCD stands for Liquid Crystal Display and DLP stands for Digital Light Processing. Both produce accurate and sharp images. The differences are in display, price and performance. ... Both DLP and LCD television screens are slim and lightweight. Best advice is here https://www.fixya.com/support/r29790007-repairing_own_television ..
Samsung... • Answered on May 26, 2021
The volume on the remote will do that!
You may have found the source of the loud bang. Time to turn it over to a repair technician.
The RL43WCIS has an LED bulb. It isn't user replaceable. See the manual available on the product support page: https://www.samsung.com/africa_en/support/model/RL41WCIS1/XFA/#downloads . The current link to the manual is https://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_AFRICA_EN&OriginYN=N&ModelType=N&ModelName=RL43WCIS&CttFileID=5099999&CDCttType=UM&VPath=UM%2F201408%2F20140825191448674%2FDA99-01220A-21.pdf . See page 19 for the description of the refrigerator parts. Page 14 indicates that a service call is needed to replace the interior light. I wish that I had better news for you. Cindy Wells
Samsung... • Answered on May 25, 2021
Televison & Video Logo
6 questions posted
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
need owners manual owners disk
  • Televison & Video
