20 Most Recent Samsung Yepp YP-T5H MP3 Player Questions & Answers
hi
follow link to samsung read the page it will give you details how to get the drivers SAMSUNG's Digital World - Support
riz.
Samsung Yepp... | Answered on Jan 11, 2019
Use the Samsung Firmware Updater to fix it. Mine did what all of you are speaking about. I was ready to toss it then I tried the firmware updater on the CD and it fixed it. You must copy all the files from the \setup\Programs\ and \setup\Binary\ folders on the Samsung CD to a folder on your hard drive. Then connect the player via USB and run stupdaterapp.exe. It will search for the device and pop up a menu. Check the Format Data Are box and click start. It takes a few minutes and wipes the device clean but it fixed mine.
Samsung Yepp... | Answered on Apr 23, 2011
Look on the side of the player.You should see a silver decal near the bottom. The third line with apx 13 digits of letters and numbers is the serial number you need.
Samsung Yepp... | Answered on Mar 29, 2010
take the hold off on the side and hold play down
Samsung Yepp... | Answered on Aug 01, 2009
Re-format? Insert it into your pc, and right click the folder from "my computer" and select "re-format" This will whipe your mp3 players files completely so you will have to put your music files back on.
Samsung Yepp... | Answered on Apr 13, 2009
Here is the page with an english version of the manual.
I went to the samsung web site and searched for you model. You will need adobe acrobat reader to view the file. If you have problems, it is small enough I could email it.
Good Luck!
Samsung Yepp... | Answered on Apr 11, 2009
The serial # should be etched onto the player itself - you may have to remove the battery case if it's not directly on the back of the player. The serial # would not be on the manual or paperwork.
Samsung Yepp... | Answered on Jul 06, 2008
Reset, firmware upgrade
There is a specific reset method - it is probably holding the power button in for 10 seconds - which caused your player to start working after the 10th try. Do a full reset. If the problem still persists, double check the Samsung website for a firmware upgrade, b/c it sounds like your DB is corrupt.
The manual and software are both available from Samsung's website
Use Windows Media Player to transfer songs.
Make sure the hold/lock is not engaged
In some rare cases, you may have to right click the device and select "enable" - but this is rare, since enable is the default
There is a hold/lock switch on the side - make sure it is disengaged - check the user's manual for the location of the switch (available from Samsung's website if you have lost it).
unable to open BOOTMANAGER
Samsung Yepp... | Answered on Mar 16, 2008
Use the Samsung Firmware Updater to fix it. Mine did what all of you are speaking about. I was ready to toss it then I tried the firmware updater on the CD and it fixed it. You must copy all the files from the \setup\Programs\ and \setup\Binary\ folders on the Samsung CD to a folder on your hard drive. Then connect the player via USB and run stupdaterapp.exe. It will search for the device and pop up1.gif a menu. Check the Format Data1.gif Are box and click start. It takes a few minutes and wipes the device clean but it fixed mine.
Samsung Yepp... | Answered on Feb 19, 2008
Samsung Yepp... | Answered on Feb 17, 2008
Samsung Yepp YP-T5H MP3 Player Logo
Popular Tags
29 questions posted
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
not english manual
  • Audio Players & Recorders
