20 Most Recent Samsung TXE2546 25" TV Questions & Answers
Can you change input on
There should be a button on the side/ It may be touch.
5/3/2011 11:11:03 PM • Samsung TXE2546... • Answered on May 03, 2011
I have samsung txe2546.
Call the company and ask them or you can look at the side of the t.v. and see a tag with the code on the side! =)
4/17/2011 2:41:54 AM • Samsung TXE2546... • Answered on Apr 17, 2011
2answers
I turned on my samsung 25' tv this morning it
it could be a bulb went out. I advise to call a tech to take a look at it. If its a CRT TV you can replace the bulb, however now a days its not that easy anymore and cost alot more. I hope this will get you on the correct path, wish you the best!
9/3/2009 4:04:08 PM • Samsung TXE2546... • Answered on Sep 03, 2009
How do I get back
To change the input source for your TV, you can use your remote to change the video source by following these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
8/17/2009 7:54:25 PM • Samsung TXE2546... • Answered on Aug 17, 2009
Samsung txe2546, how to adjust horizontal size.
Hello Laurent
This is pretty easy it's like when you adjust the imgae on your pc monitor, go to the menu then go to settings, select video or image, look for the option and just change it there.
7/12/2009 8:19:35 PM • Samsung TXE2546... • Answered on Jul 12, 2009
Tv turns on and off continually
The power supply is bad and must be replaced.
Depending on the TV and what your local repair shops charge, it might be cheaper to replace the TV. This same thing happened to me. I could replace the TV for just a little more than the cost of fixing it! I'm replacing the TV.
I'm sorry that I couldn't give you better news.
Roger
1/3/2009 8:03:28 PM • Samsung TXE2546... • Answered on Jan 03, 2009
No sound or picture
first check  if it is in AV  mode.  if true then change it to TV mode.  problem will solve ...
  In rare cases  inside the TV  board  chroma ic may gone if there are  2 ic's.
micro controller may gone if there is  only one ic...
thank u
10/26/2008 7:49:41 PM • Samsung TXE2546... • Answered on Oct 26, 2008
Samsung TXE2546 will not power up
 i think  there  should be  gone a output transister at  horizontal  stage.   if that tv is   21" or less  use  BU508F,D2499,1803DHI, OR = .......   if that tv is 25"  then use   D2508DF OR =.
if that proble is not above  then check the power suplly once  and check EHT(LOT) finally   .
10/26/2008 7:42:38 PM • Samsung TXE2546... • Answered on Oct 26, 2008
Samsung TXE2546 25" TV Problem
Check for hot spots on circuit board = solder any/all bad connects + check for bad capacitors.......T
10/26/2007 12:17:45 PM • Samsung TXE2546... • Answered on Oct 26, 2007
Vertical size
your problem in vertical outout section only. check feed back line. most probably electrolytic capacitor failure.
9/27/2007 6:10:26 PM • Samsung TXE2546... • Answered on Sep 27, 2007
An oval-shaped rainbow-like colour pattern shows first,
It May be due to one of several things. You could have some bad filter capacitors that are allowing electrical "noise" to disrupt the video, or there could be a bad solder connection or crack in the circuit board allowing a ground to "float", or there could be a problem in the Degaussing circuit, although that would be my last guess. I don't recall ever having that particular problem with any sets in my shop.
12/16/2006 7:33:58 AM • Samsung TXE2546... • Answered on Dec 16, 2006
Samsung un60es6500 won't turn on. DYI help please
Sounds like a bad y-sustain board. Unhook the board and see if the clicking goes away.
10/16/2021 2:39:17 AM • Samsung... • Answered 60 minutes ago
How do I keep the HDMI cables secure?
Buy better cables as they are not all equal. Cheap ones are made cheaply, good ones have gold flashed contacts and better made plugs. Or you can support the wire in some way. Cable ties screwed to the wall or similar.
10/15/2021 9:22:33 PM • Samsung... • Answered 6 hours ago
Samsung TV UN46D6300SFXZA won't turn on
Have you tested for power at the new outlet?
10/14/2021 11:29:51 PM • Samsung... • Answered Yesterday
Samsung UN50H6350AFXZA No Picture?
Renew the television
10/14/2021 9:27:18 PM • Samsung... • Answered Yesterday
2answers
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ... Jun 11, 2015 Samsung Plasma TV - Won't turn on Jun 11, 2015 The timer, lamp, and standby/temp. light are flashing?! Jun 11, 2015 Samsung TV Keeps Shutting Down Jun 11, 2015 More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16 https://www.youtube.com/watch?v=kFdVi2ejfzA May 8, 2014 - Uploaded by ShopJimmy.com TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
10/14/2021 3:09:40 AM • Samsung... • Answered 2 days ago
Televison & Video Logo
Popular Tags
16 questions posted
Ekse
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
tv turns off continually
  • Televison & Video
