20 Most Recent Samsung TXL2767 27" TV Questions & Answers
Universal - remocon settings
I need the code for the Sumsung Universal Remocon for my Samsung TV model TXN2726. It is an older TV 2003 model. It was given to us recently but the remote needs to be programmed and we weren't given the programming code.
1/30/2011 8:49:33 PM • Samsung TXL2767... • Answered on Jan 30, 2011
2answers
Can bad T-Con board cause Samsung TV to flicker off and on?
I think an LED problem is more likely. The LED strips are usually powered by a driver circuit on the power supply board. You can check this with a bright flashlight shining on the front of the display at about a 20° angle from parallel to the display. If you can see the picture or the menu with the flashlight beam during the "dark" period, the problem is NOT likely to be the T-Con board. You can also look at the back of the set with the cover removed - most sets have a number of vent holes in the back plate through which the backlight can be seen when it is on. If these holes go dark when the TV goes black, the backlight is being turned off. When the screen is lit, take a picture quickly and look for dark spots. Maybe one of the LEDs has a partial short that shuts down the LED power and triggers a retry cycle. If so, after a while it will burn out and then the entire LED strip will be inoperative.
11/29/2022 12:02:25 AM • Samsung... • Answered on Nov 29, 2022
3answers
Having problem with my tv. How can I fix a Samsung tv that doesn't fully turn on?
This is either a board issue or bad LED backlights, you can trouble shoot the backlights by unhooking the connector going to the main from power board plug the set in and backilghts will stay on if they're working ok, if you find they're good then I'd lean towards a bad main board, there are several ways to test the main but it would involve using a multi-meter. We've seen a lot of main board issues on this model TV.
11/27/2022 3:37:37 AM • Samsung... • Answered on Nov 27, 2022
2answers
My TV screen blinks blue on and off without any display please help
Hi, Please ensure that you're using the correct input on your samsung tv so that you're able to access your channels properly. If this is the case, then you can power cycle your tv (ie unplug for 30 seconds to 1 minute). If this fails, please remove all accessories attached to the tv and try again. Otherwise, you'll need to factory reset the tv before moving forward with a potential home repair schedule via a company like Geeksquad/Bestbuy. Thank you.
11/26/2022 4:05:09 AM • Samsung... • Answered on Nov 26, 2022
Samsung AK59-00104R remote that I use on my SAMSUNG TV no worky worky.
Change the batteries. Try that. or if not, buy a new one.
Smartby New Remote Control AK59-00104R for Samsung ...
https://www.amazon.ca > Smartby-AK59-00104R-BD-... Battery description, Lithium ; Item dimensions L x W x H · 22.1 x 8.4 x 2.8 Centimetres ; This item: Smartby New Remote Control AK59-00104R for Samsung BD-C5300 BD ... Rating: 4.5 · ‎361 reviews · ‎$29.34 · ‎In stock
11/24/2022 5:56:17 AM • Samsung... • Answered on Nov 24, 2022
I have a Samsung model UN70NU6900FXZand the problem I have is that the left side of my screen is duller/faded more than the right side.
Samsung sets with NU as the 2nd set of numbers were notorious for panel issues, sad as it sounds it may be time for a new set unless it's under warranty
11/17/2022 11:36:05 PM • Samsung... • Answered on Nov 17, 2022
Samsung un85tu7000fxza screen turning on and off every 3 seconds
This explains the issue you are facing https://www.fixya.com/support/r29790007-repairing_own_television
11/12/2022 5:42:17 AM • Samsung... • Answered on Nov 12, 2022
I have a Samsung 70 inch TV that the picture just turned grayish. I can still see the picture just turned gray
There might be something wrong with the TV's screen it's self or the cables are not properly connected or the cables are bad.
11/10/2022 8:11:29 AM • Samsung... • Answered on Nov 10, 2022
Samsung series 7 tv repeatedly turns on and off
Remove the ribbon connectors going from the tcon to panel boards, power the set up and see if it stays on then, you won't have a picture naturally but see if the backlights and sound stay on.
11/10/2022 1:37:36 AM • Samsung... • Answered on Nov 10, 2022
2answers
We have a Samsung TV UN50MU6300FXZA that stopped working after a power outage.
Hi, please switch outlets and attempt to turn the tv on. If this does not work, please schedule an in-home diagnosis from a company like Home Depot or Geeksquad. They might use a multimeter to check current flow through some of the tv circuits to determine whether the power outage damaged any of them. Thank you.
11/4/2022 9:46:16 PM • Samsung... • Answered on Nov 04, 2022
2answers
Will a 50 LG tv fit the same wall mounting bracket as a 50 Samsung tv?
Most brackets are 'Universal' by the size of television. They have enough holes to suit many sets as shown in the link. https://www.google.com/search?q=50%22+wall+bracket+for+LG+and+Samsung+television ...
11/4/2022 3:01:33 AM • Samsung... • Answered on Nov 04, 2022
My 65 curve is no longer picking up a wireless connection. All other ty's are functioning.
I would check the router is connecting with the Samsung, ensure the TV has the code entered correctly and can talk to your router.
10/30/2022 9:55:33 PM • Samsung... • Answered on Oct 30, 2022
3answers
Why won't my Samsung TV UN43TU700DFXZA come on?
On Samsung TV's with 2 blink of the standby lamp it will never be a main board issue, this code means the B+ regulator has sensed over current and shut the supply down as a safety precaution. Chances are your LED backlights are bad, several are shorted causing excess current draw, unhook the plug going to the backlights, power the set on and see if the code goes away, the set should power on, naturally you won't see a picture but would have sound if you selected the correct input.
10/29/2022 8:37:44 PM • Samsung... • Answered on Oct 29, 2022
I have a Samsung 58 TV Model UN58TU7000FXZA that wont start up.
Hi, Please double check that you're not using the same power supply. Also, please ensure that the product was built to be used in the country that you're currently using it from because if current or voltage are different between the tv and outlet, you can expect the type of problem that you've mentioned. Otherwise, you'd have to use an adapter. I would also use troubleshooting from your product manual to help sidestep the issue. Thank you.
10/27/2022 9:51:32 PM • Samsung... • Answered on Oct 27, 2022
2answers
How do I fix my Samsung smart tv version hs01
Either overheating, or there are dry joints on components.
10/27/2022 8:22:34 PM • Samsung... • Answered on Oct 27, 2022
I have 3 black lines down my Samsung plasma TV how can I fix it with spare parts
Hi, Try switching tv inputs and checking if the black lines remain. Please remove any tv accessories (ie video game console, dvd player) . If this does not work, please power cycle your tv. Otherwise, I would recommend using a tv repair service vs attempting to fix the tv with spare parts. Thank you.
10/27/2022 7:53:46 PM • Samsung... • Answered on Oct 27, 2022
Samsung TXL2767 27" TV Logo
7 questions posted
Marvin
Marvin
View Most Popular
  • Samsung Televison & Video
Most Popular Question
universal remocon settings
  • Televison & Video
