20 Most Recent Samsung TX-P3264 32" TV Questions & Answers
Try the player on another set---if works there either correct input not selected or a very odd problem in the set---I gather it works with cable etc connected to it?
Samsung TX-P3264... | Answered on May 24, 2012
Sometimes the PS3 automatically outputs it's video and audio signals in composite form. Try going back to your original composite cables and setting your system to output in HDMI. Those options would be under "Display Settings". Hope this helps!
Samsung TX-P3264... | Answered on Apr 13, 2011
The set is trying to start but it is detecting a problem so it keeps trying. Most likely you have a horizontal or high voltage problem. Hard to say. Have a shop check it out for you. Thanks
Samsung TX-P3264... | Answered on Oct 28, 2009
Check that you have selected "cable" instead of "antenna" as a signal source and then autoprogram the set. These features can usually be found through the on screen menu using front panel buttons.
Samsung TX-P3264... | Answered on Oct 24, 2009
probably get another remote from ebay
Samsung TX-P3264... | Answered on Sep 29, 2009
bottom left and top right corners, the color is off almost as if a magnent is near the screen
Samsung TX-P3264... | Answered on Jun 21, 2009
hi there,
check first all the wire connection from your unit
Samsung TX-P3264... | Answered on Mar 14, 2009
The horizontal transistor and the flyback are damaged
the neck board of your tv tube has lose solder have it resolder.
Samsung TX-P3264... | Answered on Mar 19, 2007
to start with your tv will never work with your adoption as the company who made that set did not connect that part of circuit to the tv that circuit you found is a dummy what they call a plan blue print.and instead manufactured the tv a diffrent way.
try to check your audio video chord check it if it is open. you didnt mention if your tv has video channel (tuner). if your tv video channel is o.k then the problem of your tv is in the video switcher inputs. in this case you need a service technician.
Samsung TX-P3264... | Answered on Mar 05, 2007
When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
A black screen could just be a sign that the TV is turned off, although if it is producing sound then you know that's not the case. When your TV has a black screen even when it's on, it's quite possible it could actually be your external device and not your TV.
Samsung... | Answered Yesterday
Samsung TX-P3264 32" TV Logo
20 questions posted
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung 32
  • Televison & Video
