20 Most Recent Samsung Galaxy Tab S2 - 9.7" - 32GB - Wi-Fi 4G LTE AT&T Questions & Answers
Hello Raymond McCormick,
I have recently called Customer Support at SAMSUNG...
and found them QUITE WORTHY of the modest wait...
1-855-SAM-USA1 (1-855-726-8721)
Just don't ever believe
"SAMSUNG" PARTS USA is anything but a TRAGIC
Flea Market... looking for their next prey... (clowns).
Call Customer Service They recommend using the email form, but you can also reach'em at 1-855-SAM-USA1 (1-855-726-8721) 9am - 9pm ET, 7 days a week.
Samsung
Do it now!
Samsung Galaxy... | Answered on Oct 05, 2016
if we knew what GMOD was perhaps we could .
Samsung Tab... | Answered on Oct 01, 2019
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Samsung Tab... | Answered on Oct 03, 2018
try going google and typing in ---user manual for samsung a8 tablet-- if there is a manual available it will be in pdf version for download
Samsung Tab... | Answered on Feb 01, 2018
Tip
How to make my tablet run faster
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authority.
tablet running really slow Google Search
on Nov 26, 2017 | Samsung Tab Tablets & eReaders
You would get better response if you ask just once and provide all the details available. For example, is the screen flashing blue, or another light? Exactly which model Samsung Tab E are you asking about? Have you tried contacting Samsung tech support?
Samsung Tab... | Answered on Dec 01, 2016
if its saying open it up to reset the battery..it means open it up and to take the battery out and put it back in.
please let me know if this is what you are asking,or this is what its telling you to do.
Samsung Galaxy Tab S2 - 9.7" - 32GB - Wi-Fi 4G LTE AT&T Logo
3 questions posted
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
CoppellTVRepair.com
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Tab Samsung
  • Tab Samsung
Most Popular Question
recently bought tablet in holland not
  • Tablets & eReaders
