20 Most Recent Ignition System for Kia Forte Questions & Answers
try pressing on the brake and holding, making sure car is in correct gear.
but pressing on the brake and holding, then try to rotate steering wheel!
Ignition System... | Answered on May 21, 2012
for heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
tried and tested !
Kia Vehicle... | Answered on Jan 24, 2019
Hello Ray! First let me say, although I’m not aphiliated with anyone at Kia. You have a fine vehicle! If I’m understanding you, your unable to shift into fourth gear until you’ve been driving for 30 minutes. Im assuming you mean 30 mph. This transmission will not alow you to down shift at
Kia Vehicle... | Answered on Feb 03, 2018
Change the oil and the filter to see if this helps to remedy ghe problem.
Kia Vehicle... | Answered on Sep 15, 2017
Remove all visible screws first on handles, etc. then you should be able to pop the panel off as it should be held on by clips.
Kia Vehicle... | Answered on Oct 08, 2014
sometimes the wire breaks off inside the shifter remove switch and check wires or take off the center consol and check wires if not broken inside tube but if the lights on dash flashes problem from tcm causes disengaging the overdrive and making it not functional you need a scanner to find the code or remove the battery cable for 15 mins to erase all codes and see if it works if not you need scanner
Kia Vehicle... | Answered on Sep 06, 2014
you need a scanner to be able to unlock the system and sometimes a code will be needed to have control over the adjustments usually they call the tech line with serial number and the tech gives a authorize code to secure the system should be guarentee 3 yrs 60 km or 5 yrs 100 km
Most likely a bulb has blown
Kia Vehicle... | Answered on Aug 31, 2014
Check all electrical connections to starter. Starter solenoid or starter could be worn out.
Kia Vehicle... | Answered on Aug 19, 2014
you have 4 black wires6 milimeters top of your engine take 1 of fit one in then 2nd comblete 3th and 4th you need spark plug socket go an clock wise. check the gap.
Kia Vehicle... | Answered on Jun 13, 2014
Throttle position sensor
Kia Vehicle... | Answered on Mar 02, 2014
Depending on the make but you would be looking at around 4 hours and parts. I would be thinking it is around $300 too much. Get other quotes to work out the best price.
Kia Vehicle... | Answered on Aug 22, 2013
Could be your thermostat is stuck opened or your heater core is bad,
Kia Vehicle... | Answered on Nov 28, 2012
You have a bad starter from what you are describing. Did this just happen all of a sudden? Or has it been happening until the car died?
Kia Vehicle... | Answered on Jul 30, 2012
try wiggling the steering wheel back and forth while you turn the key
Kia Vehicle... | Answered on May 29, 2012
Ignition System for Kia Forte Logo
2 questions posted
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
Marvin
Marvin
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Kia Vehicle Parts & Accessories
Most Popular Question
2012 kia forte koop key in ignition
  • Vehicle Parts & Accessories
