20 Most Recent Samsung DVD/VHS/MP3/SVHS Playback Questions & Answers
someone would have to open the unit and inspect the mechanism to see if something out of position, jammed or something similar first.
Samsung... | Answered on Oct 17, 2012
No problem,we can connect them together ..I want to emphasize that if we try to convert RCA jacks to HDMI ,you need to buy a special converter box and it cost you some $ .
However ,Even though you have not state your TV make and model but most of the today's TV's have not only HDMI but SCART ,RCA and Optical connection possibilities as well ..
So to be on the safe side I will describe all possibilities and than you will decide which way to go..
and select whichever you want..
TO WATCH DVD/VHS ON THE TV:
** Combo's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or if exist "Optic Cable OUTPUT or " SCART Output " (whichever you want ,based on the existing sockets and necessary cables on your hand ) will go to TV
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or SCART IN connector of your TV ,
** than just play DVD or VHS
TO RECORD YOUR TV Channels ON VHS .
** AT TV side : you need to connect "Audio Output and Video " as can either be : 2xRCA jacks +1xVideo or "Optic cable output" or SCART connector of your TV ,
** to VHS 's " Audio + Video input or "Optic Cable input"
or SCART of your COMBO (whichever you want ,based on the existing sockets and necessary
** than just switch to REC mode on VHS to record on whatever you watch on TV
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
NOTE: *IF you still want to use "HDMI" connection I will provide an URL link to you later than you can buy it thru internet..it is mostly not available or too expensive on local electronic markets.....
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Samsung... | Answered on Jul 27, 2011
Yes of course there is, you can buy dvd recorders, or Hard drive recorders or just a normal VCR
Samsung... | Answered on Feb 24, 2009
check www.repairworld ,dalbani.com parstore.com they might have what you are looking for
Samsung... | Answered on Jun 11, 2007
Yes. DVDs are easy as you probably already know, you just need a DVD capable drive and appropreate software to play. VHS tapes are another matter altogether. You'll have to purchase something that will convert the analog signal from the VHS player to a digital signal your PC can use. I have a device I use to convert VHS tapes to DVD (ADS technologies) I could use to watch tapes but the software leaves a lot to be desred.
Samsung... | Answered on Feb 20, 2007
sound like you have a dirty video head, try cleaning the head with some isopropyl alchol. if it does not fix your problem, then you will have a bad video head. good luck
Samsung... | Answered on Feb 15, 2007
Sounds like either corrupted firmware or something went bang in a memory or controller chip, you could try a factory reset if you can find your model number on the samsung website. If you haven't tried this yet: unplug the power plug to the TV for about 10 minutes and then try again. Sometimes this will allow the caps to drain and clear any temporary faults.
Usually a factory reset involves holding buttons on the remote while pressing the power button etc. You should be able to find instructions on how to do this with your model number. Samsung generally is pretty good about this stuff being available.
Samsung... | Answered 6 hours ago
Try it, what is the worst that can happen. :>D You just blow every component and IC in the set. You can't use it in SA anyway as it is.
It may be that the board itself can take 250 volts as far as track separation on the board is concerned, but the components on the board are 110 only.
Here is a replacement board.
https://www.buyqual.com/pd32gv0-chs-samsung-bn44-00554b-power-supply.html
This says it does work on either voltage
https://www.cnet.com/forums/discussions/samsung-power-supply-are-dual-voltage-627995/
and so does this
https://www.ifixit.com/Answers/View/530602/Is+my+TV+dual+voltage
Samsung... | Answered 17 hours ago
A modern tv is as much computer as tv and isn't electronically robust having much delicate circuitry that is vulnerable to surges, spikes or transients.
A direct lightning strike isn't necessary to cause damage and lightning activity in the area is all that is necessary. A surge protector could provide some protection but in reality disconnecting the tv from the mains and the antenna is the best protection.
In the early days of radio when circuits were more robust, an external antenna and a good ground was often necessary for good signal reception, there would be a knife switch provided to disconnect the antenna and ground it whenever there was thunder around - a worthwhile precaution that unfortunately isn't practical today.
A tv that has failed during an electrical storm might be economically repairable or might not - only the repair guy could tell you this. My limited experience with this tells me although such a tv can be fixed it never seems to achieve the same quality.
Samsung... | Answered 2 days ago
Check and see if you have power going to the fan, before replacing the fan. It could be a power board problem.
If you had sound, the power board was fine. The 'let's try changing this' method of television repair never works. You need the test equipment and knowledge at component level. Take it to an engineer, it is much cheaper.
Samsung... | Answered on Sep 22, 2020
That indicates a problem with the power supply. If your TV is under warranty, I suggest to contact the manufacturer for a repair or replacement.
Samsung... | Answered on Sep 21, 2020
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Samsung... | Answered on Sep 14, 2020
Samsung DVD/VHS/MP3/SVHS Playback Logo
9 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
  • Samsung Televison & Video
Most Popular Question
hook up older vhs dvd player new
  • Televison & Video
