20 Most Recent Everstar Portable Air Conditioner MPK-10CR Questions & Answers
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Everstar... | Answered on Jul 01, 2016
Hallo
Please send me a picture of the two wires.
I need to see it to tell you.
Everstar... | Answered on Jun 10, 2016
When you unplugged it you broken the circuit which is what it does when pan is full of water to get you by turn the two wires together to make it think the switch is made
Everstar... | Answered on Jun 06, 2016
If you noticed an electrical smell (like something was overheating), you may have a compressor lockup, or a fan lock. If you know a good, and knowledgeable handyman, he should be able to troubleshoot the unit quickly. But if it is the compressor, repairs could cost as much as a new unit.
Everstar... | Answered on Jun 02, 2016
yes it is normal . most of these have a flexable metal tube that vents them , you can use a dryer vent tube but it will get hot and even melt a little
these units do not have a long service life so don't waste your money on factory replacement parts , just use the way you are till it's used up.
Everstar... | Answered on Feb 01, 2016
Order a filter replacement...
Your filter sounds as though it's so old that it's disintigrating and bits of it are being pulled into the evaporator coil which in turn reduces the efficiency of the coil...
Everstar... | Answered on Nov 06, 2015
Water can fall off of coil prematurely, before it reaches the drain pan, sometimes due to debris on the coil surface, airflow turbulence in the return air box, and in some instances I've never resolved until the machine was replaced. The drain pan could be cracked or have blocked channels that allow water to drain from the rear to the front. It could also have ice on it/freezing up. Some will developed a thin sheet of ice and drip water. The drain line may be stopped up or broken/loose fitting. Some coils have a laminate on the aluminum fins that can deteriorate. Hope this gives you something to check!
Everstar... | Answered on Jun 13, 2015
Its a bearing problem could be the motor could be the fan this is a portable and dose need to level and sucured enough not to tip .
Grinding /rattling is the definition of a bad bearing.
Everstar... | Answered on Jun 02, 2015
check sensor
Everstar Heating... | Answered on Aug 20, 2010
. you never said what appliance this is make model nat gas lpg ??
Heating &... | Answered 2 hours ago
Everstar Portable Air Conditioner MPK-10CR Logo
Popular Tags
13 questions posted
Top Everstar Heating & Cooling Experts
Ngoro
JOHN LAPIER
Are you an Everstar Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Everstar Heating & Cooling
Most Popular Question
vent hose unit supposed get really hot
  • Heating & Cooling
