20 Most Recent Lexar JumpDrive S23 32GB USB 3.0 Flash Drive LJDS23-32GASBNA Green Questions & Answers
You may need Administrator privileges on your computer.
Plug in flash-drive.
Allow time for Windows Explorer to read it.
Run AV scan if suspect.
To get a list of attributes:
Launch Start > Run > CMD.
From the command console enter
attrib F:
(or whatever the drive letter is for your flash).
to redirect output to a text file enter (example)
attrib f:>%homepath%\flashatb.txt
From the list you should see [H]idden, [S]ystem or [R]ead only attributes for write-protected files.
You can also do it via Win Explorer by right-clicking the drive icon.
Remove all above attributes.
As a last resort, you can full-format the entire flash via explorer.
Which should wipe all files / folders on the drive.
Lexar... | Answered on Jul 05, 2018
does the card contain important data? if not would formating it help? have you a computer you could plug the sd card into and see what windows makes of it?
http://en-americas-support.nintendo.com/app/answers/detail/a_id/452/~/general-sd-card-and-microsd-card-troubleshooting
check nintendo site and see if that helps.
Lexar... | Answered on Jan 29, 2018
There is a little tab on that unit that slides back and forth. If the tab is missing, you need to use a piece of scotch tape to simulate the tab.
Lexar... | Answered on Feb 10, 2017
plug the flash drive into a usb port
it will register on the desktop and will be recognized in the computer
and given a designation--- example:- drive h---
select what you want and save as --in h
or copy /paste to h
or if you have 2 screens click and drag to h in the computer section of the second screen
Lexar... | Answered on Oct 02, 2016
Please check this link. How to Use an SD Memory Card
Lexar... | Answered on Jul 15, 2015
http://www.lexar.com/support/product-support
Lexar... | Answered on Feb 11, 2015
Either there's a little switch on the side, or the card has failed.
SD cards have a slide switch along one edge.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Lexar... | Answered on Sep 20, 2014
Once the device is recognized by your computer, locate the icon for the drive and select it, right click and scroll down to the format option on the context menu. Be sure you don't format over a drive that has necessary files as formatting will erase all files on the drive. Choose the appropriate format for the system it will be used on.....Windows, Linux, Apple etc.... Often you will have other options, such as Quick Format (most appropriate) or Complete and Utterly Long Format (which - as you might infer - takes for freakin' ever!)
Lexar... | Answered on Sep 09, 2014
If using Windows system on a computer: Click start, then Computer then find the USB thumb drive you want to format, right click on the drive and then click on "Format" on the dialog box that appears.
Lexar... | Answered on Aug 28, 2014
Just plug it in and it should be recognized by Windows and assigned a drive letter.
Lexar... | Answered on Aug 19, 2014
Try this: Go to Start, right click on My Computer, select manage. In the left pane click device manager, scroll to Universal Serial Bus Controllers. Delete all of them. System may not allow some to delete, thats fine just delete all that it will allow. Then leave your usb connected to the PC and reboot. OS will reinstall all usb drivers on its own, and it may then see your stick.
Lexar... | Answered on Aug 17, 2014
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Lexar... | Answered on Jun 22, 2014
Try
http://www.apple.com/macbook-pro/
You most likely will need a different card to be compatible with your MacBook pro. Apple website should be helpful.
you just try to add files more than 142 mb if it goes smoothly then add files up to 4 gb and then again format it in other device
Lexar... | Answered on Jun 05, 2014
What happens when you try?
Lexar... | Answered on Apr 08, 2014
Lexar JumpDrive S23 32GB USB 3.0 Flash Drive LJDS23-32GASBNA Green Logo
1 questions posted
Top Lexar Electronics - Others Experts
Ekse
John Waters
John Waters
Damon Nesselrodt
Damon Nesselrodt
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Electronics - Others
Most Popular Question
lexar jumpdrive firefly 16gb ve
  • Electronics - Others
