20 Most Recent
Razor Crazy Cart Electric Ride On Pink Questions & Answers
Why doesn't it run?
Try battery first check with digi. volt ohm meter, but yes it could be module.
Why is my 24-volt razor charger flashing red instead of green
It's likely that the 24V charger is malfunctioning. Some common reasons for this include:
1. The charger is damaged or has a loose connection.
2. The device it's charging has a low battery and is not holding a charge.
3.The device it's charging is damaged and not accepting the charge
In any case, it's best to stop using the charger and either get it repaired or replace it to prevent any potential safety issues.
How to Get Rid of Razor Bumps?
Here are the Super-Effective Ways to Get Rid of Razor Bumps.
A clean, glowing skin, devoid of any hair is what everyone wants. But things aren't that easy. The tiny red bumps always come in the way and ruin the look. These red bumps caused after shaving are known as razor bumps. If you frequently get these embarrassing bumps, then instead of stressing out, know how to get rid of razor bumps quickly at home. For more info:
https://howtocure.com/how-to-get-rid-of-razor-bumps/
