20 Most Recent Tao New Scooter 50cc Street Legal New Look Questions & Answers
The voltage for the Tao is 12 volts, but fuses are measured in AMPS not volts. It is a measure of current load. Fuses should always be replaced with the same amperage fuse as the one that came out. You need to fix the reason the fuse is blowing BEFORE you replace the fuse. Fuses only blow when the circuit is shorting to negative. If you up the amperage of the fuse and don't fix the problem, the wiring will melt and burn!!
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=b18aXeeXLoKGsQWau43IBw&q=2018+tao+tao+moped+fuse+blowing
Video showing where a short is likely to be?
https://www.youtube.com/watch?v=-7Nuo3if6SA
Tao New Scooter... | Answered on Jun 24, 2020
Hi, Eddie for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2017 Tao Tao Lancer 150 voltage regulator location Google Search
How to wire GY6 scooter regulator rectifier and how it all works Part 3...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://www.taotaopartsdirect.com/collections/lancer-150
http://absolutelyscooters.net/pdf/CGEN_dawg_scooter_manual.pdf
Tao New Scooter... | Answered on Oct 31, 2018
Hi, Michael for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tao Tao 49cc scooter wiring diagram Google Search
My Wiring Diagrams 49ccScoot com Scooter Forums
http://www.49ccscoot.com/manuals/Symply50_Service_manual.pdf
Eagle Atv Parts
TaoTao ATM50 A1 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Tao New Scooter... | Answered on Apr 06, 2017
Hi, Andi and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Headlights SOLVED SCOOTER PROFESSOR
Blinkers Horn Fuel gauge not working Scooter Doc Forum
http://www.49ccscoot.com/manuals/Derbi_Scooter_Manual.pdf
TaoTao 50cc Scooter Owners Manual
Tao New Scooter... | Answered on Nov 04, 2016
Hi, Didi for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Taotao Electric Scooter Wiring Diagram taotao electric scooter wiring...
Wiring schematics for TaoTao ATE 501 Google Search
https://taotaopartsdirect.myshopify.com/collections/ate-501-502
Tao New Scooter... | Answered on Oct 14, 2016
Incorrect tyre pressures is my guess. Or you are riding on white lines or cracks which give the impression of pulling left or right.
Tao New Scooter... | Answered on Jul 18, 2016
Automatic clutch or manual? Can be for two reasons if clutch related, the tick over is too high and the engine is connecting with the braked wheel. Or the clutch is badly adjusted and not disengaging.
Can also be warped clutch plates, but let's not go there.
Could also be the carburettor needs cleaning, (idle jet), or simply that the tick over needs speeding up. There is a screw on the side of the carb, but you have to make sure it is the right one as they is also a mixture screw. The idle screw is attached to the throttle linkage.
being a 50cc engine it should have only 1 piston
If it is a 2 stroke , it will fire every time the piston comes to tdc
if it is a 4 stroke it has to have a timing point that excites the ignition system for every 4th stroke tdc
if the exciter receives a signal to fire the plug at the wrong time , it is getting that signal from a fault or incorrect timing
that fault can be
loose wire/s,worn unit that controls the timing ( distributor fault), loose flywheel , flywheel touching coil,incorrect timing (180 degrees out ) stator loose ,rotor loose,faulty crank position sensor
it is good practice to have a workshop manual on hand and if you don't have one go google and type in --workshop manual for 50 cc tao scooter--and see if there is a pdf version in english to download
Tao New Scooter... | Answered on Mar 05, 2016
ever consider taking it to the dealer .
Tao New Scooter... | Answered on Aug 28, 2015
Perhaps indicating that the battery cannot be charged
Health & Beauty | Answered on Jul 28, 2020
Contact Tan America to request an assembly diagram, then follow it in reverse.
Health & Beauty | Answered on Jul 27, 2020
The makeup will look good on healthy skin. When I did my last makeup, I was advised to pay attention to olive skin tone https://glaminati.com/olive-skin-tone/
I just want to say it was worth it. The result was incredible.
Health & Beauty | Answered on Jul 25, 2020
Fdgregory could you please send me a copy of the manual for California gold universal gym please, I can’t find it anywhere. Thank you [email protected]
messages here are not linked so you should repost the original
Health & Beauty | Answered on Jul 24, 2020
A few questions. How old is the chair? When was it last given a service? This sounds like a power supply issue.
Try the basics first. If the batteries are removable, disconnect them and check the connectors are clean and shiny. Does the battery have a full charge in it? Is the hand control settings set too low?
If the chair is used a lot and it is an older model the batteries could be starting to get old. Batteries lose their ability to deliver power as they age. If they are OK you might need to get the motor checked. Older models use 'brush' type motors which gradually wear out over time.
Health & Beauty | Answered on Jul 13, 2020
have can open service mode in tv using ic TDA9370PS/N3/A/1932
Health & Beauty | Answered on Jul 09, 2020
????? ?? ????? ?? ??? ????? 7 ??????? : http://www.marmm.com/vitamins-needed-for-hair-and-skin/
Tao New Scooter 50cc Street Legal New Look Logo
10 questions posted
Top Tao Health & Beauty Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
Gregg Mahin
Gregg Mahin
Are you a Tao Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
Tao Health & Beauty
  • Tao Health & Beauty
Most Popular Question
bike wont work after riding all day no
  • Health & Beauty
