20 Most Recent
Samsung DVD-VR300 DVD Recorder/VCR Questions & Answers
Samsund DVD VR-300. Vcr records
Hi, this is a very common problem, its not easy to fix and it wont be cheap ok,
the problem is with the dvd drive inside the unit over time the power for the laser drops and this then causes it to stop writing to the blank dvd's how ever it will still continue to play them as this dont require the same power as it does to write to a blank dvd, i mean to get it fixed you would either need to track down a new laser or a new dvd drive because all thats inside it is a standard pc dvd re-writer but the chances of finding the exact type is slim, i would say the only way this would work out to be worth doing is if you took it to a tv repair shop and hope they have got a spare laser that is the same type as yours.
the problem is when they made these they made them as a throw away item, which i think is totally wrong as most parts can be replaced and then it could be used again, so as they are made as a throw away device they didnt supply or stock the extra parts needed if it ever went wrong, the reason they dont do this is due to the fact they bring new models out all the time so the amount of parts they would need to stock and make would be way to much and it wouldnt be worth doing unless you could do the work yourself,
when you add the price of the part to the price of the labor for someoe to fix it your looking at pretty much the same price as a new one or buying a new one wud work out cheaper than it would to repair it
if you really want it fixing then you will either need to get the part yourself and fit it yourself or take it to a small tv repair shop and see if they can adjust the pots on the laser so it records again
let me know how you get on or if you need further assistance ok
2/19/2011 1:16:08 AM •
Samsung...
Answered
on Feb 19, 2011
Samsung DVD-VR300 - cannot get VCR or DVD to play
cable from wall/outside to cable box in, cable box out to dvd/vcr in ...dvd/vcr out to tv...........set both tv & dvd/vcr to Ch 3.........
note you will not be able to record (probably) HBO on to DVD (vcr yes)
8/28/2010 3:37:03 AM •
Samsung...
Answered
on Aug 28, 2010
Hi, I have a Samsung DVD-VR300E dvd/vcr combo. The
The laser in the DVD drive may be shot (?), even though it seems to read the DVD cleaner disc. I attended a maintenance class on cleaning CD and DVD writer drives for PCs and was told not to use the disc cleaners with brushes as they can knock the laser out of alignment. It's best to use a can of pressurized air to clean a drive when it's open. Just make sure not to allow any of the propellant to get inside!
8/25/2010 1:22:07 PM •
Samsung...
Answered
on Aug 25, 2010
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
