20 Most Recent Cuisinart DLC-055 Food Processor Whisk Attachment for DLC-7 Questions & Answers
Go to manufacturer web site for download.
Cuisinart... | Answered on Apr 05, 2016
No, they are different sizes. Contact Cuisinart to replace the broken stem. Having said that, most parts are discontinued
https://www.ereplacementparts.com/cuisinart-dlc5-food-processor-parts-c-147322_147329_147422.html
Cuisinart® Food Processor (DLC-5) Parts & Accessories ...
www.cuisinart.com > shopping > food_processors > dlc-5
Food Processor (DLC-5) Parts & Accessories · Email Sign-Up.
Cuisinart® Discontinued 7 Cup Food Processor (DLC-5)
www.cuisinart.com > ... > Food Processors
Sized to be the perfect food prep companion, this Cuisinart Food Processor will mix up a little pesto for two and then puree soup for a party of seven. US$129.95
Cuisinart Dlc-5 TX Type 25 Food Processor Workbowl Pusher ...
www.ebay.com > ... > Food Processors
Cuisinart Food Processor DLC-5TX (Type 25) BASE MOTOR ONLY Tested and WORKING. Condition is used. Shipping UPS retail ground. Also checkout my ... US$34.99 · ‎In stock
Cuisinart Food... | Answered on Feb 04, 2021
Yes it does. It is a snug fit on the blade shaft, if you mean the tall shaft that powers the shredder discs? The short one that holds the cutting blade is not removable.
The tall stem is shown here
Cuisinart DLC-8 Detachable Stem
Item # 943070
https://www.kitchenworksinc.com/cuisinart-food-processor-parts/cuisinart-dlc-8-parts/
Cuisinart Food... | Answered on Jan 31, 2021
For cuisinart food processors that won't shut off: with bowl off - not attached - hold OFF button down while plugging in. With a screwdriver or other implement, press the button that gets depressed on motor base when bowl is attached and snapped into place ( small flat rectangular piece that clicks the bowl into place. While still pressing OFF button, press this a few times times, unplug then release the OFF button. I tried several suggested combinations of button pushing and unplugging, and this seems to have fixed it!
Cuisinart Food... | Answered on Jan 18, 2021
The control board (AKA PCB) will need to be replaced.
Cuisinart Food... | Answered on Dec 08, 2020
The DLC-8F bowl will not work for the DLC-8M, as I understand the parts list for the 11 cup food processors. However, this site, https://www.kitchenworksinc.com/cuisinart-dlc-8-4-piece-tritan-bowl-kit/ , has a work bowl for the DLC-8 food processor. The bowl fits all models of DLC-8 except the DLC-8E and DLC-8F. The link for the work bowl alone is https://www.kitchenworksinc.com/cuisinart-dlc-8-tritan-workbowl/ .
I hope this helps.
Cuisinart Food... | Answered on Jun 01, 2020
Hello, Sally -
Make sure you have the work bowl properly placed on the base and the lid properly attached to the work bowl. I often have trouble getting the work bowl inserted in the base of our food processor and also have trouble getting the lid fitted into the bowl properly.
Since I have no idea which model of Cuisinart food processor you have, I am unable to advise you further.
You can contact Cuisinart Product Assistance:
US toll free number:
800-726-0190
Monday to Friday, 8:00 AM - 10:00 PM (Eastern Time)
Saturday and Sunday, 9:00 AM - 5:30 PM (Eastern Time)
Best wishes.
Cuisinart Food... | Answered on Jan 03, 2019
Tip
Don't throw out your Cuisinart-Keurig SS-700 if the switch is broke.
Would you pay $1.84 to fix it? Cuisinart does NOT carry the #1 part most likely to fail, the on-off rocker switch. Most of the parts they do carry you'd only need if you were careless and broke the item, but the switch gets daily use and these snap-in switches are not made to last to begin with. The switch is not listed on their web site and if you call they will tell you it's time for you to buy a new machine. If you are a handyman to the extent of having a solder iron and a Phillips screwdriver then the switch can be bought from a commercial electric/electronics supply house. The shipping costs seven times more than the switch, and much more if you want air freight. The switch itself is $1.84. It's a medium task and will take about 30 minutes tops. The most time taken was 7 days waiting for the normal shipment to arrive. It's PN 15N8920 from Newark Element14 @ "https://www.newark.com/". They are a wholesaler and I didn't volunteer that I wasn't a contractor or business. In the online order form when it asked for company I filled in "Retired" and I answered all the other application form questions they had so I could return there again I needed something they carried. Their form didn't ask if I was a re-seller and my answer would have been "no" but if it had gone down that rabbit hole I may not have been able to order. In my order I bought two of the switches; by the time my SS-700 fails and needs another switch I'll probably be glad I bought the backup. For Cuisinart not to carry that switch is planned obsolescence IMHO. Yes, a homeowner who is not handy with some basic tools might be unable, but even a small town repair business might not go through the trouble I did because they'd have to pay and pass along to you the $20 (90% for shipping)for the part, and by the time they add on a reasonable charge for labor your bill would probably be $70-$90. Facing that amount you might think buying a new one is best for you, you'd get all new, the latest, including a warranty. Imagine if an Ace Hardware or Home Depot carried that switch (I looked), I'd have had it working the same day. Keurig could buy a higher quality switch to manufacture with, but there's more revenue for them going the way they are now, and this planned obsolescence every product maker uses puts more permanent waste in our landfills.,
on Dec 20, 2018 | Cuisinart Food Processors
The set screw on the blade assembly is loose. If the motor does not spin then that is a different story.
Cuisinart Food... | Answered on Dec 10, 2018
Cuisinart DLC-055 Food Processor Whisk Attachment for DLC-7 Logo
1 questions posted
Top Cuisinart Food Processors Experts
Lawrence Oravetz
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Cuisinart Food Processors
Most Popular Question
need manual dlc 055 cuisinart whisk
  • Food Processors
