20 Most Recent Samsung VR3607 VHS VCR Questions & Answers
There is a problem with the loading basket, or the VHS tape is stuck inside and the eject mechanism can not cycle the tape out. To check this, open the lid so you can see the tape, if it is wrapped around the head and roller, hit the eject button to see if the tape is being pulled or jammed, cut the tape with scissors to free it up to see if it will pop out. If the tape is okay, it means you have a faulty loading basket.
Samsung VR3607... | Answered on Dec 30, 2010
following is pasted from SV-7000W manual: 1 To lock the VCR, hold down the P/STILL (II) button for approximately five seconds. Result: The lock indicator (LOCK) is displayed. If a cassette is in the VCR when you lock it, the cassette will first be ejected. 2 To unlock the VCR, hold down the P/STILL (II) button again for approximately five seconds. Result: The lock indicator (LOCK) is no longer displayed. If that fails, try the same thing using the play/stop button. Cheers
Samsung VR3607... | Answered on Feb 18, 2009
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set. If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Samsung VR3607... | Answered on Dec 29, 2008
This again, is set via the remote, in the on-screen menu.
Samsung VR3607... | Answered on Jun 04, 2007
The power light should be off when the TV is on.
If you are sure the TV is the issue and not the remote then yes changing the board is the only option.
Samsung... | Answered 12 hours ago
it is a 3D TV. Viewing without glasses in 3D will show ghosts. ry the glasses.
Samsung... | Answered 2 days ago
Sounds like either corrupted firmware or something went bang in a memory or controller chip, you could try a factory reset if you can find your model number on the samsung website. If you haven't tried this yet: unplug the power plug to the TV for about 10 minutes and then try again. Sometimes this will allow the caps to drain and clear any temporary faults.
Usually a factory reset involves holding buttons on the remote while pressing the power button etc. You should be able to find instructions on how to do this with your model number. Samsung generally is pretty good about this stuff being available.
Samsung... | Answered 3 days ago
Try it, what is the worst that can happen. :>D You just blow every component and IC in the set. You can't use it in SA anyway as it is.
It may be that the board itself can take 250 volts as far as track separation on the board is concerned, but the components on the board are 110 only.
Here is a replacement board.
https://www.buyqual.com/pd32gv0-chs-samsung-bn44-00554b-power-supply.html
This says it does work on either voltage
https://www.cnet.com/forums/discussions/samsung-power-supply-are-dual-voltage-627995/
and so does this
https://www.ifixit.com/Answers/View/530602/Is+my+TV+dual+voltage
A modern tv is as much computer as tv and isn't electronically robust having much delicate circuitry that is vulnerable to surges, spikes or transients.
A direct lightning strike isn't necessary to cause damage and lightning activity in the area is all that is necessary. A surge protector could provide some protection but in reality disconnecting the tv from the mains and the antenna is the best protection.
In the early days of radio when circuits were more robust, an external antenna and a good ground was often necessary for good signal reception, there would be a knife switch provided to disconnect the antenna and ground it whenever there was thunder around - a worthwhile precaution that unfortunately isn't practical today.
A tv that has failed during an electrical storm might be economically repairable or might not - only the repair guy could tell you this. My limited experience with this tells me although such a tv can be fixed it never seems to achieve the same quality.
Samsung... | Answered on Sep 25, 2020
Check and see if you have power going to the fan, before replacing the fan. It could be a power board problem.
If you had sound, the power board was fine. The 'let's try changing this' method of television repair never works. You need the test equipment and knowledge at component level. Take it to an engineer, it is much cheaper.
Samsung... | Answered on Sep 22, 2020
That indicates a problem with the power supply. If your TV is under warranty, I suggest to contact the manufacturer for a repair or replacement.
Samsung... | Answered on Sep 21, 2020
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Samsung... | Answered on Sep 14, 2020
Samsung VR3607 VHS VCR Logo
6 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
  • Samsung Televison & Video
Most Popular Question
set timed recording
  • Televison & Video
