20 Most Recent
Eclipse 1 Pc Touch PRO 4gb Mp3video Player Cobalt Questions & Answers
Why wont my eclipse touch pro player turn back on it was just working?
click the following link and scroll down to the bottom of page 5 & the top of page 6... Those Eclipse mp3 players have a 60 second automatic lock on them. This pdf is the instruction manual for your mp3 player.
https://cdn.shopify.com/s/files/1/0632/6269/files/Eclipse_Touch_Pro.pdf
How do i put music on my Eclipse mp3
go to mp3juices.cc and download then go to computer open 2 windows then go to downloads one of the boxes click the mp3 driver and drag over into the file desired by opening and dropping.
What is err_no=0x50000011 - Eclipse Audio Players & Recorders
"err_no=0x50000011" is an error code that may appear on an Eclipse audio player or recorder. This error code typically indicates a problem with the firmware or software on the device. The specific cause of the error and the steps needed to resolve it may vary depending on the model and specific circumstances of the device.
Here are a few things you can try:
- Restart the device: Sometimes, a simple restart can resolve software issues.
- Update the firmware: Make sure that the device has the latest firmware version.
- Check the SD card: If the device uses an SD card, make sure that it is properly inserted and that the card is not damaged.
- check the battery: Make sure that the device has enough battery or that it is plugged in.
- Reset the device: If none of the above steps work, try performing a factory reset on the device.
- Consult the manual: Consult the manual for specific troubleshoot and service information for your Eclipse model.
Hello my eclipse mp3 player will charge but when i take it off the charger it plays for 3 minutes and truns off and i just bought it new what can i do to fix it
It sounds like you are experiencing an issue with your new Eclipse MP3 player. Here are a few things you can try to troubleshoot the problem:
- Make sure that the battery is fully charged. If the battery is not fully charged, the MP3 player may not have enough power to stay on for an extended period of time.
- Check the charging cable and make sure that it is securely plugged into the MP3 player and the charger.
- Check the charging port on the MP3 player for any damage or debris that may be preventing a secure connection.
- Try a different charging cable or charger to see if the issue is with the charging equipment.
- If the issue persists, you may need to contact the manufacturer for further assistance.
I hope this helps! If you have any additional questions or need further assistance, don't hesitate to ask.
Download songs to my mp3
I always download songs use a youtube downloader from youtube.It can not only download videos from youtube but also convert the videos to the right forma tyou want while it is downloading.You can take a try for this
free youtube downloader.
My eclipse 2.8 mp3 player won't charge
Hi Lezlee Johnson, as you comment, it is very possible that the battery of your Eclipse, is not making good contact or has already fulfilled its useful life
Review and comment
Regards Franco Dosil
Hola Lezlee Johnson, por lo que comentas, es muy posible que la bateria de tu Eclipse, no esta haciendo buen contacto o ya haya cumplido su vida util
Revisa y comenta
Saludos Franco Dosil
When i play videos on my eclipse fit clip plus it says format error i dont know what issue it is pls help
There are many different video formats and some players will only play certain formats. Check which formats the player will play. Then look at the formats that it wont play.
If the player won't play those that it's supposed to, then you will have a problem. If it does play them and not others, then you need to remove those files it won't and get then converted to ones that can play on your player. There is free software available to convert files on a computer. But some might want to charge you for converting common file types.
