20 Most Recent Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Questions & Answers
Turns on, get the Vizio logo for a second then why does it go black?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/
10/18/2018 2:34:26 AM • Vizio E500i-B1... • Answered on Oct 18, 2018
My Vizio e500i-b1 LEDtv went out last night. How can i tell if it's the main board or the tcon board that isn't functioning?
I would verify the voltages on the power supply board first because an improper voltage to a circuit board may make that board look bad.
8/29/2018 11:07:19 PM • Vizio E500i-B1... • Answered on Aug 29, 2018
How do I fix black vertical line on one side of the screen seemingly caused by impact damage?
This kind of problem is not fixable, you need a new LCD panel.
1/15/2018 11:58:26 PM • Vizio E500i-B1... • Answered on Jan 15, 2018
I have a vizio model E500I-B1, SERIAL LTY6PLYQ5254714 that I'm having some issues with.. it seems to have intermittent back like issues. can anyone advise me where to start?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1/24/2017 8:56:17 AM • Vizio E500i-B1... • Answered on Jan 24, 2017
Led tv occasionally has picture but always audio. What is the problem?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
10/15/2016 1:46:03 PM • Vizio E500i-B1... • Answered on Oct 15, 2016
Replace wifi module on Vizio E500i-B1
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
7/25/2016 2:52:13 AM • Vizio E500i-B1... • Answered on Jul 25, 2016
2answers
No back-light,No picture, but has sounds. How can I fix it?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/29/2016 2:46:12 AM • Vizio E500i-B1... • Answered on May 29, 2016
There is a horizontal line halfway 3/4 across the screen, it's not black it's just a different color.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
5/14/2016 11:46:16 PM • Vizio E500i-B1... • Answered on May 14, 2016
Vizio e500i b1 black screen, no image
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1/25/2016 3:46:08 PM • Vizio E500i-B1... • Answered on Jan 25, 2016
0answers
Vizio E420-A0 starts to power on, flickers, powers off
As long as you're getting the standby lamp you will see the standby voltage like you have. Vizio didn't really have issues with caps although I can't say Ive never had any bad. As far as backlights, you can see them through the back of the set with the back off but even if they're not working chances are that's not your issue as Vizio has local dimming and generally they don't all fail so I don't think backlights is your issue. I would suspect main board issues, to be more exact I think your EEPROM has bad data, it's an IC you can change if you have experience in soldering small devices as a new IC can be purchased for about $15, easy way to fix would be replace the main board and they aren't all that expensive in this model...below is a listing for one from shopjimmy, by far the best place to get boards...I wouldn't buy from ebay as in a lot of cases the boards are bad
1/19/2022 5:20:49 PM • Vizio Televison... • Answered 3 days ago
My vizio tv m55-c2 has a ghosting menu picture on top one third of the screen, what can i do to fix my self
Try replacing the tcon board, if that doesn't fix it you have a bad panel and it's not fixable
1/17/2022 7:07:00 PM • Vizio Televison... • Answered on Jan 17, 2022
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
17 questions posted
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio model e500i b1 serial
  • Televison & Video
