20 Most Recent Keurig K550 2 0 Brewer Black Questions & Answers
Why is my Keurig 2.0 not brewing full cups of coffee and unable to dispense only hot water?
I answered a previous question but as this has more information let me suggest you descale your system. you can purchase a kit at Bed, Bath, and Beyond, or go online and learn how.
10/5/2016 4:21:10 AM • Keurig K550 2 0... • Answered on Oct 05, 2016
Brews one or two cups then puts ground in coffee
If you are using the "store bought" Keurig brand K cups for making coffee in the machine, you may just need to clean it by running several "cups" of just water - NO K cup - thru it, into a large white cup. This will NOT hurt the machine, but will clean out most residual grounds in it. The white cup will show you what comes out. Then hold the machine over the sink and using the sink sprayer, open the lid, pop out the K cup holder and spray hot water down thru the opening where the K cup holder sits, then wipe everything you can reach, top and from below, inside and out, with a damp dish towel over one finger. Then clean the K cup holder with hot water and an old toothbrush and reinstall it. EZ. If this doesn't completely fix the problem, check the soft black rubber (neoprene) seal that fits around the top puncture needle inside and under the lid that comes down over the K cup when you close it to brew. You can't see this part very well, but you can feel it with fingers easily. It is about 3/4" in diameter, maybe 1/4" thick and just slides on over and around the top needle. (there is a bottom needle in the K cup holder, too) If this seal is damaged or missing, that's the problem. It needs to be cleaned every few months anyway, just pop it out, rinse it and replace it. EZPZ. Now, if you are doing the "load your own coffee" aftermarket plastic cups, the problem may be the refillable cup. But you need to do the cleaning steps outlined above anyway. There are a variety of these, I have them all and use my favorite ones. Some of these plastic cups will deform over time and not seal against the seal described in the paragraph above. If this is the problem, do all the above plus replace the refillable cup. Try a different kind this time. These machines are very well designed and made. The inside of these coffee machines are CRAMMED FULL of tubes, valves, wires, pumps, a boiler, and electronics. They are NOT designed to be repaired, just replaced. But the above cleaning should be done on every one of them every few months and they will last for years.
3/23/2016 9:57:37 AM • Keurig K550 2 0... • Answered on Mar 23, 2016
Keurig k155 touch screen blank
If the touch screen of your Keurig K155 brewer is blank, here are some steps you can try to troubleshoot the issue:
  1. Check the power supply: Make sure the brewer is properly plugged in and the outlet is working. Try unplugging and plugging the brewer back in to reset it.
  2. Clean the touch screen: Use a soft, damp cloth to clean the touch screen, as dirt and debris can interfere with its function.
  3. Perform a hard reset: Unplug the brewer from the power source and remove the water reservoir. Press and hold the power button for 5 seconds, then release it. Wait for 2 minutes, then plug the brewer back in and turn it on. Reattach the water reservoir and try using the touch screen again.
  4. Contact customer support: If none of the above steps work, you may need to contact Keurig customer support for further assistance. They may be able to offer additional troubleshooting steps or provide repair options if needed.
5/1/2023 6:43:28 PM • Keurig Coffee... • Answered on May 01, 2023
2answers
Keurig model 65.0100.3052702. Where is the fuse on it please?
There is no internal fuse.
2/14/2023 5:10:10 AM • Keurig Coffee... • Answered on Feb 14, 2023
Can I continue to use my Keurig after it started smoking?
It will be fine, just descale it. It wasn't electrical smoke, but steam and hot limescale from the heating element and being empty..
2/8/2023 2:47:54 PM • Keurig Coffee... • Answered on Feb 08, 2023
Keurig keeps saying water under pressure and will not release?
The cause is that the needle inside the machine is dirty or blocked. You can see this article to clean the Keurig needle!
2/4/2023 3:26:06 PM • Keurig Coffee... • Answered on Feb 04, 2023
My Keurig will not brew. Why are you going to charge me $5 to fix your expensive machine?
fixya is not keurig notify them
1/10/2023 11:13:52 PM • Keurig Coffee... • Answered on Jan 10, 2023
My keurig 2.0 is not working. power icon is on but nothing happens when i press it. tried unplugging and also switching outlets with no success
This problem can be solved by cleaning the screen properly. If the cleaning doesn't work there might be a connection problem. For that, you have to reassemble the screen of your Keurig machine. Read this article for a complete fixing guide
9/15/2022 7:43:58 PM • Keurig Coffee... • Answered on Sep 15, 2022
3answers
The touch screen on my Keurig 2.0 comes on but you can not push any of the buttons...they don't work!
The problem with the touchscreen not responding, is caused by dirt/coffee residue, getting under the bezel around the screen. Sometimes a tissue soaked in Windex, then polished with a dry one , will temporarily remedy this. The only permanent fix is to disassemble the head, remove the lcd screen and clean it thoroughly, as well as under the bezel.
9/15/2022 7:42:32 PM • Keurig Coffee... • Answered on Sep 15, 2022
Keurig shuts off after i push the brew button?
Some of the most likely reasons by which Keurig keeps shutting off while brewing includes: Machines require Descaling or cleaning. The bottom of the k-cup is not punctured. Misaligned magnet in water Reservoir In this article , all these reasons are discussed in detail, which might help you
9/9/2022 12:46:09 PM • Keurig Coffee... • Answered on Sep 09, 2022
3answers
My Keurig turns off when I press the brew button. ???
You will need send it in for repair
9/9/2022 12:44:36 PM • Keurig Coffee... • Answered on Sep 09, 2022
Cusinart keurig coffee maker not working
What's With the Cuisinart SS-10 "EEO" Message?
A few reports surfaced that gave me cause for concern: A number of people were getting "eeo" error messages in the menu window. What panned out is that these were inoperable. When there were error messages like "add water" and "descale" that were out of line with the consumer's actions, the simple act of unplugging and waiting a few minutes then re-plugging it back seemed to take care of it Also as per the manual, pressing and holding the Hot Water and Rinse buttons simultaneously will reset the machine and get rid of the nuisance "Descale" message that has irked some owners. But as I found out later -The user manual under the Troubleshooting section says if you get "eeo" in the display window to "Call customer support" along with the number, so it is a whole other ball game - a sensory defect, and clearly a sign of a dud. And this on Just Answer regarding a 2 month old machine. Thanks for your question I'm Martyn, welcome to JA. This Error has been a reported issue with some models... a faulty tube is suspected As it is only 2 months old, Warranty issues need to be dealt with by the store where the appliance was bought in the first instance... DO NOT attempt any repair or you WILL VOID your Warranty Call the supplier first, and they will deal or refer you I hope I've been able to provide you with the information you were seeking. If you are happy with my service, your positive rating, before we finish up here, is most welcome. Need more help about this issue ? Please let me know. And then I found this in a video. Press and Hold the Hot Water and Rinse buttons will reset the machine. And finally from the manual, "Call Customer Support". https://www.manualslib.com/manual/1078422/Cuisinart-Ss-10.html?page=20 Please let me know how you get on as I haven't come across this error before. ..
4/21/2022 3:32:16 PM • Keurig Coffee... • Answered on Apr 21, 2022
Where is the magnet on the Keurig coffee maker?
https://www.ifixit.com/Guide/Adjusting+Keurig+K75+Platinum+Brewing+System+Reservoir+Magnet/13023
10/3/2021 12:16:53 AM • Keurig Coffee... • Answered on Oct 03, 2021
KEURIG LID HANDLE WILL NOT STAY UP WHEN REPLACING A K CUP
Hi Julia, I have a problem answering your question as I do not know what module you have. These typically have a life span of 3 to 5 years, if it has reached that age or older consider replacing it. The most inexpensive option is just to hold the handle when replacing the cup.
10/2/2021 2:27:49 AM • Keurig Coffee... • Answered on Oct 02, 2021
6answers
New Keurig B140 will not pump or prime
On the water reservoir there is a little black disk, a magnet, I think... If that is not against the machine it will display the prime error. Empty the water from the reservoir and tilt it so that the disk is against the machine. Place the reservoir empty back on the machine and fill it with water carefully as not to move the disk. When the water level gets to the correct position, the prime error will go away.
9/12/2021 8:10:18 AM • Keurig Coffee... • Answered on Sep 12, 2021
Keurig K550 2 0 Brewer Black Logo
3 questions posted
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Keurig Coffee Makers & Espresso...
  • Keurig Coffee Makers & Espresso...
Most Popular Question
keurig 2 0 not brewing full cups coffee
  • Coffee Makers & Espresso Machines
