20 Most Recent
Brother MFC9340CDW Wireless Printer Scanner Questions & Answers
Replaced waste toner box. Continue to receive "Replace Toner Box" message. Have insured that all parts back in properly. Will not print.
There is normal a clear plastic section on most waste toner boxes that tell the printer / copier how much toner is inside check to make sure it is clear! Dump the toner out if you don't have a new one BE CAREFUL CAN GET VERY MESSY. DO not use water to clean up use vacuum but do be care toner particles are small enough to go thru some vacuum filter so try some small amout make sure it does not spray your wall! Also check make sure the toner box does not have any broken small tabs the indicate to the printer thr the box is properly installed, one other check if the box has clear section match that section in the printer and clean that area sensor the monitors the clear section may have toner in it. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
10/18/2022 1:19:20 AM •
Brother...
Answered
on Oct 18, 2022
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place.
2. Lift up the front panel from the device.
3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
Visit my computer
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
Brother is in an error state
4 Solutions of Brother Printer In Error State Windows 10:-
1. Beginning of all, you want to make sure that all the wires and joints of the printer are fit and don't have a loophole.
2. Make sure your machines connect correctly, try with Another USB port and the network or cable you use for the attachment has no problem.
3. Further, Switch off the printer and check for paper jams then close all trays accurately. If it has a paper jam gently remove it.
4. Verify if the printer is low on ink, refill it if it is. If you are using a WiFi printer, turn on the WiFi of the printer and the modem router.
The cause why you get this error state note on your Brother printer is either your printer is not connected perfectly, the printer jammed, low on ink, and any software changes. There can be other reasons as well, which can cause the problem of the Brother Printer In Error State Windows 10.
Full Blog -
