20 Most Recent Apple - iPhone 6 Plus 16GB Questions & Answers
GT Recovery for Windows Download: http://www.gtrecovery.net
We use Facebook daily to do conversation with our friends, relatives and sometimes with our profession clients too.
It's very important for us to get those conversations back if mistakenly they can deleted.
Some common situations that lost Facebook private messages you can recover from:
1). accidentally deleted it on your android phone
2). lost messages after Android 5.0 updated or other Android upgrade.
3). save messages from water damaged, crashed, broken or smashed Android phone
4). Android delete facebook messages randomly by itself
5). Factory restore Android phone.
Apple - iPhone 6... | Answered on Jan 03, 2020
If you didn't remember your passcode to get into iPhone, you have to reset the passcode. There are a few ways to reach this aim. Check below steps to do that.
If you haven't synced your iPhone with iTunes before or if you haven't enabled your Find My iPhone on, you can take advantage of the third method. Resetting iPhone Password in Recovery Mode is not complicated. The steps below will show you how to do that.
Step 1. Disconnect all cables from your iPhone and turn it off.
Step 2. Press and hold the Home button and connect your device to iTunes. If your iPhone does not turn on, please turn it on manually.
Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode.
Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone.
Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you reset iPhone password with Recovery Mode. Therefore, please consider carefully whether you need to use this method to reset password on iPhone.
If you remember your current iPhone password and you just want to change into a new password, you can finish it with ease. Go to Setting > General > Touch ID > Passcode (iOS 9/8/7) or Passcode Lock (iOS 6), then enter the current password and tap Change Passcode. Then enter the new passcode. Now, you have reset your iPhone password.
For more methods, check: How to Reset Password on iPhone
Apple - iPhone 6... | Answered on Jul 26, 2019
Did you mean that you forgot the passcode to iPhone and your iPhone have been locked? If so, follow below method to reset the passcode and unlock your iPhone.
If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
If you forgot the passcode to your iPhone, there still are a few methods to reset the passcode. Check one of them shown below.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
Be careful booking trips on the internet especially using your debit or credit card because they could do at 2 if you're going to do any orders or taking any trips make sure that your internet settings on safe mode always for your computer or laptop
Apple - iPhone 6... | Answered on Oct 09, 2016
Did you enable the find my iPhone feature? If so go to Apple's website and you can track your phones location.
Also, try calling the people that were in your meeting. Perhaps one of them saw it.
Apple - iPhone 6... | Answered on Sep 21, 2016
Apple's instructions here.
https://support.apple.com/en-us/HT204306
Apple - iPhone 6... | Answered on Sep 02, 2016
Did you forget your passcode to your phone? Try plugging your phone in to your PC and open iTunes. You can restore your iPhone from a backup and you can have more chances to unlock your phone.
Apple - iPhone 6... | Answered on Aug 02, 2016
Julio, Dry phone as much as you can, then seal phone in a plastic bag with a 1/2 lb of rice to help remove moisture. This has helped some in the past revive wet small electronics.Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple - iPhone 6... | Answered on Jun 03, 2016
Those cases do tend to be so thick with their screen protectors that it can be hard to touch the screen. My advice is to try pressing as hard as you can, with warm fingers. Because the screen senses body heat. If you still have trouble, it might be the case specifically and you should contact the company and see if you can get a refund.
Apple - iPhone 6... | Answered on Apr 25, 2016
Hi Malibu , If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
Apple - iPhone 6... | Answered on Apr 10, 2016
There are retailers who offer unlocking services
Apple - iPhone 6... | Answered on Apr 07, 2016
You should use the 'forgotten password' feature.
I have read of others having same problem of missing tones after restore or upgrade. Fwiw - I always save backups of everything on my iphone to my PC using iTunes and only use iCloud as my secondary backup. Using iTunes allows selection of each category including "tones". Even though the tones were restored, I found that each contact was reset back to default. I had to go back to each contact, select "edit" and then select "ringtone" which brought up the listing of available tones and all my custom tones were at the top of the list.
if you purchased ringtones or downloaded free ring tones from the iTunes Store and they are missing, you should be able to go to the iTunes Store on your iPhone, select "more" then select "purchases" and re-download them, they may only be listed under the music category. Although I also have heard some people are missing ring tones from their purchases. In this case, you will need to email or call apple customer service.
if all this fails, your can use iTunes or any other music editor to make your own ring tones. Basically you save a copy of the song in m4a format, edit the start and stop times to be 30 sec max play time and save the clip as an .m4r file. You can google the procedure, it's fairly easy. In iTunes, save the clip with a new title then go to the actual file location on the hard drive and simply change the file extension to m4r, then add the file to iTunes and it will show up under "tones", repeat as desired then you can sync the tones.
without iTunes, you need to use an app to make ring tones on your iPhone - Apple has not yet provided this functionality.
Apple - iPhone 6... | Answered on Mar 10, 2016
Apple - iPhone 6 Plus 16GB Logo
37 questions posted
Popular Products
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
unlock icloud locked iphone 6 bought
  • Cell Phones
