20 Most Recent Samsung CXD1342 13 in. Combo Questions & Answers
2answers
The volume up button on
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
10/13/2011 2:58:53 AM • Samsung CXD1342... • Answered on Oct 13, 2011
Need the remote code to my Samsung TV. My model
Hello
Three digit universal remote code for Samsung Tv are:
002 012 102 103 112 212 502 512 818 914
Four digit remote code for Samsung TV/VCR/DVD combo is
0942
DVD/VCR cobo are:-
0455 0963
TV/DVD combo is
0942
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
12/28/2010 3:16:20 PM • Samsung CXD1342... • Answered on Dec 28, 2010
Old Bose 321 system has no HDMI port.According to Samsung,I cant view system settings without HDMI port on Bose.
The back of the bose appears to have lots of RCA connectors. I do know you can get RCA to HDMI Converters. The back of this link shows the Television connection, Image 3 and Click Zoom + https://www.crutchfield.ca/S-XupivCi9We5/p_018321GSS2/Bose-3-2-1-GS-Series-II-Gray-with-silver-satellites.html?XVINQ=DGC&XVVER=AAA&awcp=&awcr=201614511552&awdv=c&awkw=&awmt=b&awnw=g&awug=9000809 and the converters https://www.google.com/search?q=rca+to+hdmi+converter ..
11/28/2021 1:35:42 AM • Samsung... • Answered 12 hours ago
2answers
Samsung ln46d630m3f sound no picture
What's the part number of the power board? Not sure where it would have said that connector 801 has 273 VAC as it would be impossible to get that voltage from a modern power supply board, max would be 120 volts ac times 1.4 or about 165 vac
11/27/2021 7:21:58 PM • Samsung... • Answered 19 hours ago
3answers
My samsung LTF320AP08 television shows black screen and then coloured vertical lines . It has volume but no image of channel
When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty. A black screen could just be a sign that the TV is turned off, although if it is producing sound then you know that's not the case. When your TV has a black screen even when it's on, it's quite possible it could actually be your external device and not your TV.
11/27/2021 7:21:14 PM • Samsung... • Answered 19 hours ago
3answers
Samsung backlight on and off w/ no picture?
Fault with the main power supply [SMPS] board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size
11/24/2021 9:47:23 PM • Samsung... • Answered 3 days ago
3answers
I have one single black vertical line on my Samsung tv?
The screen and the LCD are no longer working for your TV or the capacitors have gone bad.The hardware needs to be replaced for your TV.
11/24/2021 6:21:24 PM • Samsung... • Answered 3 days ago
Samsung TV QN55Q75FMFXZA black screen with audio.
It could be caused by a connection problem with the cables or loose connections with the cabling or the TV is set up on the wrong input.
11/19/2021 10:02:45 AM • Samsung... • Answered on Nov 19, 2021
TV half screen is dark ?
Hi Jay...UN55NU7300FXZA will be the model of your TV not the power or main board numbers, the boards will start with BN-44 but the number you have isn't going to be the board numbers in your TV. An educated guess would be your LED backlight strips are bad and the ones not lighting are making part of the screen dark, it could be a power board but it's seldom those give backlight issues. Changing the backlights on a curved set isn't an easy job as the screen is hard to remove and install once you've had it out. There is a good chance it will get damaged handling it, I've been repairing sets for a number of yrs and I have a hard time with them and I have the equipment to handle them, at a minimum you need 4 suction cups as you can't handle them safely without them.
11/18/2021 12:59:06 AM • Samsung... • Answered on Nov 18, 2021
Samsung 55" SUHD power issues.
Are you able to get the back off to take some voltage readings, this set has the screwless back and it's not easy to get off without the removal tool
11/17/2021 1:34:39 AM • Samsung... • Answered on Nov 17, 2021
Samsung CXD1342 13 in. Combo Logo
Popular Tags
7 questions posted
Ekse
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
volume up button
  • Televison & Video
