20 Most Recent Samsung UN40HU6950 40 Inch Ultra Smart Questions & Answers
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Samsung... | Answered on Sep 24, 2019
Sounds like a power board issue. Unfortunately this is a common problem in flat screen TVs. Typicality this happens after the tv is three years old or older. Some will last several years. The repair is almost cost prohibitive. The replacement board if you sent it out to a repair shop would cost approximately $190.00 and altleast two hours labor $180.00 for the repair. Most repair shops also charge for a diagnostic fee. That fee most likely would be around $50.00.
Samsung UN... | Answered on Jan 18, 2019
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Samsung UN... | Answered on Oct 27, 2017
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung UN... | Answered on Jul 27, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Samsung UN... | Answered on Apr 01, 2016
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
Samsung UN... | Answered on May 30, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
Try opening your menu options and search for "updates" Usually when you set your TV for the first time it usually guides you to do this firmware update. Try acting like your are setting up your TV for the first time and maybe it will have a option for this.
Samsung UN... | Answered on Apr 03, 2015
new hdmi cable
Samsung UN... | Answered on Sep 08, 2014
Main digital board fault. Contact the authorized service center for Samsung. Gopakumar Gopalan Google
Samsung UN... | Answered on May 19, 2014
Main board fault. Contact any service technician; or the authorized service center for Samsung. This is not a user repairable fault. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Samsung UN... | Answered on Jan 24, 2014
Samsung UN40HU6950 40 Inch Ultra Smart Logo
1 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
UN Samsung
  • UN Samsung
Most Popular Question
get audio work samsung un40hu6950f uhd
  • Televison & Video
