20 Most Recent Fitbit Charge Wireless Activity Tracker Sleep Wristband Small Questions & Answers
You held the button to long and it is in exercise tracking mode. See http://help.fitbit.com/articles/en_US/Help_article/1935
You might alao want to go to Help.fitbit.com and download your manual
Fitbit Charge... | Answered on Jun 02, 2016
Did you ever figure out the problem with your V106 code? My has the same issue right now. Thank you
Fitbit Charge... | Answered on Dec 02, 2015
Change from 24 hour clock to 12 hour clock
Fitbit Charge... | Answered on Mar 20, 2015
Here's your video tutorial hope this helps..
Exercise &... | Answered Yesterday
You can Follow these steps:
Click the Dashboard link at the top of this page to visit your Fitbit.com dashboard.
Click the profile icon on the top right side of your dashboard.
On the left side of your profile page, under your default profile photo, you will see links to "change profile pic" and "upload pictures." Click Upload pictures to do so.
Once you've successfully uploaded an image, click the small grey gear icon to set your chosen photo as a profile image.
At this point you should see your Fitbit.com profile image change to reflect your selection. To ensure that image is able to be displayed on the community, you'll also want to check the Privacy Settings in your account.
Still on your Fitbit.com Dashboard, click the gear icon in the top-right corner.
Click Settings, and then choose Privacy from the list on the left.
Make sure your Profile Photo is set to be visible to Anyone.
undefined. Save your changes and read all the stories
Hope it helps.
Thanks
Exercise &... | Answered 3 days ago
It could be a fault with the motor controller board, in which case the motor controller board would need to be replaced.
Or it could be that the motor itself is shorted or open or otherwise broken
Exercise &... | Answered on Sep 13, 2020
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Exercise &... | Answered on Sep 11, 2020
Fitbit Charge Wireless Activity Tracker Sleep Wristband Small Logo
24 questions posted
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Fitbit Exercise & Fitness
Most Popular Question
going fitbit charge when in get clock
  • Exercise & Fitness
