20 Most Recent TCL 40FS4610R 40-Inch 1080p 120Hz Smart LED TV Roku TV Questions & Answers
Then it is time for you to take to a pro for repair or just replace new
TCL 40FS4610R... | Answered on Mar 28, 2019
It is with its firmware problem itself. Do firmware update. If you wish to get more details, Google for the site "Electro help"
TCL 40FS4610R... | Answered on Sep 02, 2018
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
TCL 40FS4610R... | Answered on Sep 15, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
TCL 40FS4610R... | Answered on Jun 06, 2016
by turning up the volume button on roke remote and tv
TCL 40FS4610R... | Answered on Mar 09, 2016
did the box come with a cable and instructions .read instructions then attach cable where it suggests they go . set tv input to that cable and it should work .
TCL 40FS4610R... | Answered on Oct 01, 2015
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
TCL 40FS4610R... | Answered on Dec 19, 2014
try update your TCL TV firmware by current update version file from USB stick
https://electronics-tricks.blogspot.com
TCL Televison &... | Answered on Jan 03, 2020
Replace the power supply.
TCL Televison &... | Answered on Jun 24, 2014
TCL 40FS4610R 40-Inch 1080p 120Hz Smart LED TV Roku TV Logo
12 questions posted
Top TCL Televison & Video Experts
john h
Andrew Taylor
Andrew Taylor
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
connect t uverse cable box
  • Televison & Video
