20 Most Recent
Samsung HCN529W 52" Rear Projection Television Questions & Answers
SAMSUNG HCN4727WX XAA CH P55A-N REV.1
If total dead follow the money or in this case the voltage--start with AC into the power supply--its likely on input side of power supply as if standby was working you would see or hear something........at the bridge rectifier it will of course change to DC but that is just before the AC goes unswitched to the standby supply which has to be ON 7/24.
No picture. Power's up,
power def board is bad i have been trying to find out what exactly on the board is bad but have had no luck.
The color is split.
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
- Screen Looks 3-D
- Colors wont align
- Screen may look distorted or warped
- No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
- Dull looking picture
- White looking picture
- Halos around objects
- Red/Orange looking picture
You can see some more examples and find the fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Samsung tv hcn529w
this does require soldering the ic's you have to change there are two of them plus sometimes you have a bad resistor or two and some bad pico fuses if you can solder and have a meter you could do it
Samsung rear projection TV audio no video
There is a problem on the deflection board (BP94-00501B). I have tried replacing the flyback, both convergence IC's and the horizontal output transistor without any luck. I finally bought the whole board from encompass parts for ~$120. Hope this helps.
Power to unit but will not turn on.
You need to replace your STKs Both of them they are convergence ICs and do control startup. they are big black ics STK392-040 also ck (2) resistors-- RZ142 3.9ohms RZ145 3.9ohms .To order Parts Call Electronix 1-800-223-3205.
