20 Most Recent
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Questions & Answers
Could be a bad/failing fan. Is the fan still vibrating? Is it making more noise then normal? Most of the time i find that a fan going bad and vibrating raises heck with the rest of the optics in the TV.
Samsung HLP6163W...
Answered
on Jan 02, 2018
It is either a power supply problem or the supply trying to protect itself from a failure elsewhere.
This limiting action also can prevent an unwanted fire from overheating.
You will require service to restore your set.
Samsung HLP6163W...
Answered
on Mar 20, 2015
I have a benq projector which has a very noisy color wheel can I stop it or how do I replace it
Samsung HLP6163W...
Answered
on Jan 25, 2014
bad solder connects on power supply pcb.........t.
Samsung HLP6163W...
Answered
on Jun 22, 2013
You don't mention if you get a picture or not but you might want to check the lamp for signs of damage. I think you will want to check samsung's website samsung.com/support and type in your model, some of these model are experiencing similar problems and there might be a firmware update for this.
Samsung HLP6163W...
Answered
on Dec 04, 2012
Remove and inspect the lamp to see if it shattered inside?
Samsung HLP6163W...
Answered
on Oct 25, 2012
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Samsung HLP6163W...
Answered
on Oct 18, 2012
Hi,The lamp is on the back of the TV. Remove the little door or the back cover to get to the lamp.Here is the link for the video showing you how to remove the lamp.http://www.youtube.com/watch?v=0jr_9A5Xd2QGood luckwww.aaatvservice.com
Samsung HLP6163W...
Answered
on Sep 03, 2012
Likely the DMD unit which is part of the light engine--if have to unplug set the microprocessor is getting scrambled and cannot operate. Common and fatal issue as to replace the light engine the cost will exceed the value of this set---DMD can be purchased alone but costs almost as much as the whole engine that comes with it.Seen several of these sets---a shame but even at wholesale the part to fix it makes it not worth fixing.
Samsung HLP6163W...
Answered
on Jun 01, 2012
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Samsung HLP6163W...
Answered
on Apr 06, 2012
