20 Most Recent Exterior for Ford Focus (3 Door) Hatchback Questions & Answers
IT will be difficult to get a parts break down of what you want so I suggest two things . Go to a wreckers and look at a door lock the same as yours or go to the dealer spares and have a look at their break down to see what would have broken. Most spares people are willing to help correctly identify the parts for you.
Exterior for... | Answered on Aug 05, 2013
Can anyone help me get the code for my ford focus 2005 model radio code sam model 222599250900 ?i would very much appreciated anyone could help me with this thanks in advance
Ford Vehicle... | Answered on Dec 11, 2019
Search for on google
Ford Vehicle... | Answered on Mar 19, 2019
Which transmission? Some bands are not adjustable without getting into the transmission case.
Ford Vehicle... | Answered on Feb 19, 2019
A qualified service center can ask a dealership for the code or go directly to the dealer.
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Ford Vehicle... | Answered on Jan 29, 2019
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of all the times I fixed the chipper in these 4 years
Ford Vehicle... | Answered on Jan 25, 2019
Just a guess, since some disengage if signal not getting thru that motor running, to prevent starter brushes overheating, burning, etc, and you say motor starts, maybe a dirty electrical connection, like oil or something got in somewhere, interfering with that signal being received. To rule that out I guess yourself or shop, have all electrical connectors looked at for oil, dirt, oxidation, loose, etc... Simply pulling connectors and pushing back on few times might do it if that the issue. Notice if it feels tight or not. If oily dirty, maybe spray male and female parts of connector with alcohol based spray degreaser. Silicone spray has fast evaporating alcohol but the silicone may interfere with electrical connection. Also, be sure your remote button not triggered by weak spring contacting when you set it down or put in pocket as that'll act to shut off if already on. I had 1 get like that. Would park car, head in, putting remote in pocket after going in, would notice car running from inside.
Ford Vehicle... | Answered on Nov 09, 2018
either a stuck closed thermasa or a waterpump
Ford Vehicle... | Answered on Oct 21, 2018
it could be a couple of things. it could be the main blend door actuator. the other could be a blower motor.
Ford Vehicle... | Answered on Sep 21, 2017
These aftermarket remote start system are famous for this type of problem, I think it has lost communication with the car's security system, how to fix that I am not aware of.
Ford Vehicle... | Answered on Nov 22, 2016
that is a factory setting on the computer, not user serviceable. talk to ford.
Ford Vehicle... | Answered on Jun 06, 2016
The fuse panel is below and to the left of the steering wheel by the brake pedal. Remove the cover to access fuse panel. There should be a fuse puller tool fastened to the fuse panel cover. check the fuse in position number 10(it should be a 10 amp fuse). Also check relay number 5 which is the Rear Defrost Relay. If both the fuse and Relay are good, check under the hood for the power distribution box. Locate it, disconnect the battery, open the power distribution box, check fuse number 121 (it should be a 20 amp fuse). Check also fuse number 116(it should be a 30 amp fuse). Replace the faulty one(s) and then close the Power Distribution Box. Reconnect the battery. Hope this helps! Blessings!
Ford Vehicle... | Answered on Mar 02, 2016
Tip
How to remove the rear bumper on a ford ranger 1999
This a short video on how to remove the rear bumper and install a new one on a 1999 ford ranger xlt
on Feb 21, 2016 | Vehicle Parts & Accessories
try putting transmission in neutral instead of park , or if clutch equipped try depressing clutch all the way down
Ford Vehicle... | Answered on Jan 29, 2016
Disconnect the battery for half an hour,make sure you have your radio code written down.if that fails you will have to take it to the dealer who will have a computer to plug into yours.
Ford Vehicle... | Answered on Nov 17, 2015
Exterior for Ford Focus (3 Door) Hatchback Logo
1 questions posted
Top Ford Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Ford Vehicle Parts & Accessories
Most Popular Question
need parts breakdown right side door
  • Vehicle Parts & Accessories
