20 Most Recent LG 8GB G Pad 7.0" Wi-Fi Tablet Black Questions & Answers
0answers
0answers
0answers
How do I get my LG 7.0 tablet out of safe mode?
Get an Android Tablet out of safe mode Use the following steps to get out of safe mode.
    1.Restart your device by holding the power button, then tap Power off. 2.Tap Ok to confirm. 3.Power the device on. Your tablet should now be out of safe mode. If the device is still in safe mode use one of the following methods.
      ·Uninstall the last application you installed: 1.From the Apps menu, tap on Settings. 2.Tap on the app and then tap on uninstall. 3.Restart your device. ·Perform a factory data reset: 1.From the Apps menu, tap on settings, and then tap backup and reset. 2.Tap on factory data reset, and then tap reset tablet 3.Tap erase everything to format your tablet back to factory default configuration.
11/22/2015 2:52:48 AM • LG 8GB G Pad... • Answered on Nov 22, 2015
Turned sound off. When turned back on why do I still have no sound?
I'd suggest to reboot the device.
6/24/2015 5:24:11 AM • LG 8GB G Pad... • Answered on Jun 24, 2015
Went to use it and it won't come on. Thought battery might be dead and plugged it in and it still won't come on.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges. If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up. In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes. You are much better off recharging when 50% depleted than using it up til your product stops. L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
3/11/2015 6:10:59 AM • LG 8GB G Pad... • Answered on Mar 11, 2015
I have a lg g pad 7.0 and it keeps freezing on me how do i get it to stop freezing up?
Sounds like a software issue. If possible see if there is a update for the device. That could help with the freezing problem.
12/2/2014 5:44:32 AM • LG 8GB G Pad... • Answered on Dec 02, 2014
Google locked lg gpad x 8.0
Sadly, you need this information to use the phone. At the moment, there are some online resources that claim that they can bypass the Google lock however I've not used any such service and can't verify their claims.
12/26/2018 9:05:09 PM • LG Tablets &... • Answered on Dec 26, 2018
How can I bypass a Google account on a lg lk460 tablet
If it's telling you the tablet is locked and requesting Google credentials to continue, you can't bypass that. That's an anti-theft feature. You'll have to have the owner of the last Google account who logged into the tablet log into it to continue.
9/26/2018 10:27:55 PM • LG Tablets &... • Answered on Sep 26, 2018
To connect my fintie keyboard to my LG tablet
If that's a BT (bluetooth) kb, you need to go to the tablet Settings, Bluetooth, turn on BT, you might have to tap the More link/button, locate the kb, and add it to get it to pair.
4/29/2018 1:12:51 PM • LG Tablets &... • Answered on Apr 29, 2018
I have an lg tablet & my cellular network is with Consumer Cellular & as long as I'm on wifi it works. What do I need to do to be able to use my network away from wifi?
If it does not an ethernet connection you are out of luck. If you have an Iphone you can turn on hotspot.
4/22/2018 5:30:11 AM • LG Tablets &... • Answered on Apr 22, 2018
LG 8GB G Pad 7.0" Wi-Fi Tablet Black Logo
11 questions posted
Top LG Tablets & eReaders Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • LG Tablets & eReaders
Most Popular Question
get lg 7 0 tablet out safe mode
  • Tablets & eReaders
