20 Most Recent
Packard HP 2514 Deskjet All-in-One Print, Scan & Copy Inkjet Printer Questions & Answers
Hp deskjet 2514 reset ink level
You are not giving any error codes or messages from the printer, so I can't pin point the error. But you could try to check all contacts from the cartridges and in the printer, because jus a small piece of paper, sticky tape or dust can destroy the communication, needed to let the printer do its work. Al contacts should be clean and shiny. Make sure the cartridges gave a little click when you pressed them in place.
RE: Vibe USB Turntable Model:
your choice of "Vibe" turntable could have not been worse.
Any serious Vinyl collector would not use such a cheap piece of equipment.
You Get What You Pay For is so very true in this case.
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
