20 Most Recent Hisense 40" Smart TV Full HD 1080p LED HDTV with Built in WiFi - 40K20D Questions & Answers
I need help on how to connect the network on my Hisense smart tv. I don't know the model number or how to find it.
Does your TV have RJ45 connector ? That looks like 26263581-kbmxcsgdcjwkxkxfv11waner-3-0.png Insert a RJ45 patch cable from the router to that port using taht looks like this 26263581-kbmxcsgdcjwkxkxfv11waner-3-2.png Your TV should AUTOMATICALLY now be on the network
9/6/2016 8:16:52 PM • Hisense 40"... • Answered on Sep 06, 2016
Can anybody please help me with the 3 digit code for the hisense tv to activate my universal remote please.
Ok what kind of tv do you have? I need the make model ? And what kind of remote do you have?
4/30/2016 2:38:09 PM • Hisense 40"... • Answered on Apr 30, 2016
2answers
I have a Wizard 2 universal remote.What is the ode to operate the above tv?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the ‘device’s brand name list’ in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.http://electro-medical.blogspot.com/
4/7/2016 8:42:47 PM • Hisense 40"... • Answered on Apr 07, 2016
Need code for universal Wizard 2 tv remote to operate the hisense 1080p tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://electro-medical.blogspot.com/
4/7/2016 8:16:43 PM • Hisense 40"... • Answered on Apr 07, 2016
How can I hoop up an antema to TV?
That depends on the type of antenna, but in general it attaches to the same jack as your cable would. On the tv setup menu there witll be an option for cable or antenna, and then you'll need to run a scan to setup the channels. If the antenna you chose doen't have a ***** on connetor like cable, you can get an adapter at Radio Shack.
3/28/2016 12:37:48 AM • Hisense 40"... • Answered on Mar 28, 2016
Tv turns on normal, after about 5-10 min loud screeching sound and tv goes blank, reset by unplugging and turns on normal again only to repeat the cycle.
Hi Laz Televisions get power supply unit problems that do exacly what your describing. It is Caused by ageing Electrolytic Capacitors. If your not tech savvy then take it to a technician otherwise Find & Replace the Caps yourself Try These Switched mode power supply How to Replace an Electrolytic Capacitor Good Luck
3/14/2016 6:46:11 AM • Hisense 40"... • Answered on Mar 14, 2016
Hisense tv is stuck on retrieving data, then goes to no signal. Desktop is hooked up to it.. desktop was working with hdmi before
I had the same problem right up until the HDMI stopped working altogether. I had to use the ''component'' cables instead. The problem in my case is a bad HDMI socket (circuit board). The word ''randomly'' caught my attention. That's exactly how it happened with mine.
1/2/2015 1:52:20 AM • Hisense 40"... • Answered on Jan 02, 2015
Hisense 50r6e blinks twice pause and again
It's not a hardware issue, you have bad LED backlights...VERY common failure on this and most model TV's
10/19/2021 9:25:03 PM • Hisense... • Answered 2 days ago
2answers
Hisense TV go On for 3 sec, see TV logo, then turn OFF.
Why did you replace the power board for an overheating or fault protection issue? The "let's try changing this part" system of repair never works. Diagnose with all your test equipment, consult with service specs, speak to the manufacturer in China, and replace the one part that needs replacing. Hopefully our Expert Larry will be along shortly. https://www.fixya.com/support/r29790007-repairing_own_television ..
9/30/2021 2:08:03 AM • Hisense... • Answered on Sep 30, 2021
Hisense model #75r6e1 has sound but no picture. Conducted flashlight test and can see images in background.
Chances are your LED backlights are defective
9/27/2021 10:11:33 PM • Hisense... • Answered on Sep 27, 2021
Hisense backlight replacement
The blue strips stop the LEDs from making contact with the metal chassis. The whole process is shown here. https://www.shopjimmy.com/hisense-hd500df-b53-replacement-led-backlight-strips-11-50h5gb-50h4c-50h5c/ https://www.google.com/search?q=backlight+for+my+Hisense+50H5C ..
9/21/2021 4:24:12 AM • Hisense... • Answered on Sep 21, 2021
3answers
Hisense 55R6E no picture /no sound
This model set had defective LED lamps from the factory and only lasted 1000 plus hrs...You can get lamps that will last from shopjimmy that will fix the issue for about $60 with shipping. Its not a hard job changing them, just takes some patience and care when handling the screen as it's extremely fragile on most lower price sets.
9/19/2021 6:17:32 PM • Hisense... • Answered on Sep 19, 2021
CAbles for Hisense Roku TV
Walmart and Target and Amazon and Kmart and whichever TV provider that you guys are using would have cables for your TV then.
9/18/2021 8:35:45 PM • Hisense... • Answered on Sep 18, 2021
Hisense LED LCD TV, Model 50H5C NO Video No Sound
Your LED backlights are bad and need replacing, it's something you can do yourself but look at some youtube vids before attempting to do it, the panel is extremely fragile on this model set, be careful handling it or it will break then the TV is junk and the money spent on lamp strips is waisted. Also match the old strips to the pictures of new ones as this model uses 2 styles of strips, best place to buy them is shopjimmy.com
9/16/2021 5:49:26 PM • Hisense... • Answered on Sep 16, 2021
Hisense 58R6E no sound no picture?
This model had a lot of backlight issues with the lamp strips being bad, order a new set and install them and it will work again, but be careful handling the panel, it's VERY fragile
9/8/2021 4:18:44 PM • Hisense... • Answered on Sep 08, 2021
2answers
Blink codes for a 58 Hisense TV
The back light and the LED and the screen went bad and should be replaced.
8/23/2021 8:12:46 AM • Hisense... • Answered on Aug 23, 2021
50k23dg Blue Screen with Vertical White Lines
The main board and the power supply is bad for your TV and it would be more easier to buy a new TV than to try and fix the current TV that you have and that our TV could of had died on you.
8/23/2021 8:12:39 AM • Hisense... • Answered on Aug 23, 2021
In need codes for hisense
What code
8/11/2021 3:25:13 PM • Hisense... • Answered on Aug 11, 2021
Hisense 40&quot Smart TV Full HD 1080p LED HDTV with Built in WiFi - 40K20D Logo
11 questions posted
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
need help connect network hisense smart
  • Televison & Video
