20 Most Recent
Samsung PROSTAR816 PLUS PHONE SYSTEM Elec System Questions & Answers
Does not ring
Hi Sandra, this sounds like your phone that is not ringing needs to be added to a group- I have sent you a video showing how to do this. go to
www.abbeytelecom.com for more training videos relating to the Prostar 816
1/28/2011 1:57:44 PM •
Samsung...
Answered
on Jan 28, 2011
How do you adjust the hold timer
the feature code for adjusting the timer is in MMC 501, however if you place a call on hold and press the hold button twice in quick succesion it will stay on hold for a lot longer. On
www.abbeytelecom.com there are around 60 videos which deal with the Samsung Prostar DCS, I have posted the most popular as an example for future reference
1/24/2011 12:54:56 PM •
Samsung...
Answered
on Jan 24, 2011
THe display feature on one of our phones (Prostar
Sometimes the display will come back on if you unplug the phone at the socket, then plug back in. If this doesn't help then you need a new phone, this might be covered on your
maintenance contract. I've posted a 'how to change the date and time' video on for future reference, there's lots more at
1/18/2011 8:39:54 PM •
Samsung...
Answered
on Jan 18, 2011
Beeps on hold on Samsung IDCS 100
On the system 100, you have to go into system under technician level programming and set it to trunk MOH=371 and station MOH=371 . the out put from the MOH device is punched down on the first punch block that the first 8 stations are on, generally the yellow orange pair. If you want to continue I will get you the information you need to install it. Keep in mind, I do not know if the default system password for technician level programming has been changed or not.
11/10/2010 1:19:24 PM •
Samsung...
Answered
on Nov 10, 2010
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
