20 Most Recent
SanDisk Sansa e140 MP3 Player Questions & Answers
Sansa e140 error
There is a Problem with the flash memory on the Mp3 player I would request u too replace it
I droped my mp3player in the tolite while cleaning the bathroom
To dry out the MP3 player put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours, and hope it will work properly again, but if does not work then it is faulty and you need a new MP3 player.
I need it reboot
Take out the batteries for 3o seconds then put them baack in and turn it on again.
SD card suddenly says write protected
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
MP3 is dead. Is there some trick to reboot?
Press and hold the power button (menu) in your e140 for about 30+ seconds. Now try powering on your Sansa.
If it doesn't work, press and hold select (center button) alongside pressing and holding power button. Probably this should work for you.
Dead e 140
Could u pls try to connect the Mp3 player to a diffrent usb port
Cant delete songs from player
Paul,
You can't delete songs from the player itself. You have to plug the player into a computer. Then go to the player, find the songs you don't want, and delete them.
Yeah, seems odd to me too. But Sansa have confirmed that there isn't any way to do this from the player. Cheers!
