20 Most Recent RCA 8" Android Tablet w/Dual Tuner Questions & Answers
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
12/31/2019 2:24:22 AM • RCA 8" Android... • Answered on Dec 31, 2019
Why am i not getting any sound from my tablet?
Try updating your app if not hold vol button down while pressing the power button at the same time. Hold it for 15secs to 45sec it should rest and YouTube should be refreshed
3/31/2016 7:36:23 AM • RCA 8" Android... • Answered on Mar 31, 2016
Unable to get internet
You can separate the troubleshooting into parts. Go to a place having a wi-fi internet hot-spot, like Starbucks or Gloria Jeans'. Assuming you are in the USA: http://www.wififreespot.com/ Get a coffee and turn your tablet wi-fi on. From http://www.manualslib.com/manual/742236/Rca-Rct6272w23.html?page=11#manual 1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position. 2. The device will scan Wi-Fi networks automatically and display the available names. • If the device finds a network that you connected to previously, it will connect to it automatically. 3. Tap a network name to connect to it. Tap 'Agree to conditions' if necessary. You should then be able to go to a webpage. Once you get this bit working, you can turn to your home internet. You need of course an account with an ISP, who will probably supply you with a gateway (modem/router). If you only have a modem (connection box to the ISP) that does not have a wi-fi capability, you will need to get a router (wi-fi broadcaster). These can be quite small and neat. http://phandroid.s3.amazonaws.com/wp-content/uploads/2015/10/OnHub-by-ASUS-Screen-Shot-2015-10-27-at-5.29.02-PM.png For assistance on this contact your ISP tech help line, since some of the advice is peculiar to the equipment they use. Connect the router (if you needed to get one) to the modem with an ethernet cable http://cdn2.pcadvisor.co.uk/cmsdata/features/3502678/ethernet-cable.jpg and follow the setup instructions that came with it. Then do the same as in the cafe wi-fi hot spot. It should work. .
3/3/2016 11:20:33 PM • RCA 8" Android... • Answered on Mar 03, 2016
Have ever herd of this thing can you help please
It could be that your dimmer control got pushed all the way to the bottom. Try this: Touch Settings > Display > Brightness and move the slider to at least the middle. If this doesn't work then perhaps your backlighting lights have failed
5/11/2015 9:07:44 PM • RCA 8" Android... • Answered on May 11, 2015
Battery was low. connected it to charger. comes on and off but apparently not charging. While on charger it flashes on and off.
Try a different plug, If not i would consider buying a new charger. If that does not fix it you need Tablet help
3/14/2015 11:02:45 PM • RCA 8" Android... • Answered on Mar 14, 2015
How do I setup or download free of the bible
Play store .
1/4/2015 9:50:23 AM • RCA 8" Android... • Answered on Jan 04, 2015
I want to download free material on my rca tablet
I do not know what you are asking
12/11/2014 6:26:45 AM • RCA 8" Android... • Answered on Dec 11, 2014
My tablet model rct6077w2 wont turn on
My tablet model rct6378w2 won't stay turn on
2/11/2019 5:31:20 PM • RCA Tablets &... • Answered on Feb 11, 2019
2answers
RCA tablet how do you reverse camera
how to reverse the camera soI will be able take picture without the camera facing front
1/29/2018 8:08:51 AM • RCA Tablets &... • Answered on Jan 29, 2018
3answers
Rca tablet is frozen
Same with me but it got cracked so I brung it inside and it froze idk what to do :(
8/1/2017 4:27:58 PM • RCA Tablets &... • Answered on Aug 01, 2017
Can not get wifi to work on rca tablet
I happened to a 7" rca tablet I bought about a year ago I just reset and it works fine now.Thanks!
10/21/2015 4:10:12 PM • RCA Tablets &... • Answered on Oct 21, 2015
My sons RCA tablet fell and now the screen is doing mirror image.
Hello Mama, Try pressing Alt Ctrl and the UP arrow keys at the same time. It worked for me.
8/7/2015 5:03:54 PM • RCA Tablets &... • Answered on Aug 07, 2015
2answers
Forgot password
You'll need to do a factory reset: 1. With the device off, press and hold Volume Up and Power. 2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears. 3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection. 4. Press Volume Up continue. This will reset you device to factory settings, however anything on your SD card will still remain. At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
7/1/2015 1:09:38 PM • RCA Tablets &... • Answered on Jul 01, 2015
Rca tablet will not turn on
If you look on the back of your tablet. You should see a tiny word that reads "reset" the hole Is tiny so using a earring to press it will turn it on. After that it should turn on then plug it up to the charger. My tablet does it so I have to do it alot.
3/6/2015 12:32:41 AM • RCA Tablets &... • Answered on Mar 06, 2015
2answers
My RCA tablet died and it wont turn back on
If you have the correct charger, let the tablet charge for a full 24hrs, actually i think 10hrs will be ok and try turning it on, also you can google how to do a reset for your exact model tablet. I have another brand tablet and that worked.
1/3/2015 7:47:56 PM • RCA Tablets &... • Answered on Jan 03, 2015
0answers
My tablet is on Safe mode and dont know what or where to go or do to get it back normal operating mode rca 7inch tablet model rct
The only way is to hook it up to computer and boot with software it came with. Or you can download it from website. Since it could mean possible hardware failure. Either by water or moisture I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
6/23/2014 5:07:59 PM • RCA Tablets &... • Answered on Jun 23, 2014
RCA 8" Android Tablet w/Dual Tuner Logo
Popular Tags
10 questions posted
Top RCA Tablets & eReaders Experts
matt
matt
ADMIN Canada
ADMIN Canada
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Tablets & eReaders
Most Popular Question
set password wi fi orca android tablet
  • Tablets & eReaders
