20 Most Recent Chromo Inc Vuru T2 7" Android JellyBean Tablet PC - Multi Touch. 8GB Flash Local Memory. HDMI Port Bonus HDMI Cable Included. Dual Core CPU. Integrated Dual Camera 2MP - Pink - April 2014 Questions & Answers
I forgot my PIN and unable to access
Hi there, it is very easy to break your pattern lock if you already forget any of your android devices, but there is one condition, it is only possible if you already enabled "usb debugging" option in the "developer mode". if not you can't break your lock, if you already enabled usb debugging, you can use any pattern lock remover software, it is very easy to do. here is the download link Android Multi Tools v1 02b FAISAL JEE rar , in case of mobiles, you want to tap on build number for 7 times to enable Developer Mode, which you can find under "About Device" (last option in settings) you can learn these method for future if not working at this time, Thank you. 25930015-p1n5iiptevsfye4curpni4ns-4-0.jpeg
10/28/2015 10:55:04 PM • Chromo Inc Vuru... • Answered on Oct 28, 2015
Bypass a forgotten lock code
Make sure the tablet has been turned off first by holding down the power button until you get the power off dialog box and choose power off. Then hold down the volume button and while continuing to hold the volume button, hold down the power button until you get a message like 'booting into recovery mode' or a dialog box that allows you to go into recovery mode and do a factory reset. Some tablets may boot into a screen with the Android robot on it that you can touch the robot and get to the recovery mode screen. When you do a factory reset, all user information stored on the tablet will be cleared, including the passwords or lock codes.
1/5/2015 3:54:17 AM • Chromo Inc Vuru... • Answered on Jan 05, 2015
0answers
Is it bad for the battery to leave your tablet plugged in all the time?
it's not optimum as in second chart in article at battery University:
https://batteryuniversity.com/article/bu-808-how-to-prolong-lithium-based-batteries
It says better to not leave at 100%, better to exercise some electrons, LOL it's better for battery chemistry
2/6/2023 6:23:33 AM • Tablets &... • Answered 3 hours ago
2answers
My Lenovo tablet 4 touch screen
may be a hardware issue
2/5/2023 8:37:53 AM • Tablets &... • Answered Yesterday
How can you protect an iPad from liquid damage?
Here are a few steps you can take to protect your iPad from liquid damage:
Keep liquids away from the device: Avoid exposing your iPad to liquids as much as possible, and keep it away from drinks, spills, and splashes.
Use a case: Invest in a good quality, water-resistant case for your iPad. This will provide extra protection in case of accidental spills.
Turn off the device: If your iPad comes in contact with liquid, turn it off immediately and unplug it from any power source.
Dry it thoroughly: Use a soft, lint-free cloth to dry your iPad as much as possible, paying special attention to the ports, buttons, and speaker grilles.
Avoid using heat: Don't use a hair dryer, oven, or other heat source to dry your iPad. This can cause additional damage to the device.
Avoid using a vacuum: Don't use a vacuum cleaner to try and remove any remaining liquid, as this can cause static electricity and further damage to the device.
Take it to a professional: If your iPad has been damaged by liquid, take it to a professional repair service as soon as possible. Delaying repairs can lead to further damage.
It's important to note that liquid damage to electronic devices is often not covered by warranty, so taking steps to protect your iPad from liquid damage is important for preserving its longevity.
2/1/2023 3:05:05 AM • Tablets &... • Answered on Feb 01, 2023
Where can I find a operating system for my nuvision TM785M3 Tablet my tablet is screwed up
You can try the following steps to find an operating system for your NuVision TM785M3 tablet:
  1. Visit the NuVision website and check if they have any firmware updates or operating system downloads available for your specific tablet model.
  2. Search online for the specific operating system version that your tablet was originally shipped with. For example, if your tablet was originally shipped with Android 6.0, search for "Android 6.0 firmware for NuVision TM785M3."
  3. Be aware that downloading firmware from unofficial sources can be risky, it can cause further issues on your tablet. Make sure to download the firmware from a reputable source.
  4. Once you've downloaded the firmware, you can try to flash it to your tablet using a firmware flashing tool such as Odin for Samsung devices or SP Flash Tool for MediaTek devices.
  5. If you're not comfortable with flashing firmware, you can also contact NuVision technical support for assistance.
It's important to note that, if you're not comfortable with this process or if you don't know what you're doing, it's best to contact a professional technician or Nuvision technical support to help you with this process.
1/21/2023 11:12:42 AM • Tablets &... • Answered on Jan 21, 2023
Where is the enter key on Tablet 4gx Enhance
The location of the enter key on a Tablet 4gx Enhance may vary depending on the specific model and manufacturer. Some tablets have a physical enter key on the keyboard, while others may have a virtual enter key on the on-screen keyboard. You can check the manual of your tablet or do a quick search online to find the specific location of the enter key on your device. If your tablet does not have a physical keyboard, you can find the enter key on the on-screen keyboard. It's usually located on the right side of the keyboard, next to the spacebar.
1/21/2023 11:06:54 AM • Tablets &... • Answered on Jan 21, 2023
2answers
How come my new onn tablet won't keep a charge
possible bad battery.
1/18/2023 4:28:17 AM • Tablets &... • Answered on Jan 18, 2023
2answers
Tablet turns on with message DEVICE MAPPING TABLE
The message "DEVICE MAPPING TABLE" typically refers to the process of mapping the physical layout of the storage devices in a computer or tablet. This message may appear during the boot process, indicating that the device is loading the map of where data is stored on the storage devices (such as a hard drive or SSD). This message is generally not a cause for concern and the device should continue to boot normally.
1/17/2023 5:01:51 AM • Tablets &... • Answered on Jan 17, 2023
Chromo Inc Vuru T2 7" Android JellyBean Tablet PC - Multi Touch. 8GB Flash Local Memory. HDMI Port Bonus HDMI Cable Included. Dual Core CPU. Integrated Dual Camera 2MP - Pink - April 2014 Logo
8 questions posted
Top Chromo Inc Tablets & eReaders Experts
ray gallant
W.L.
 Mikey
Mikey
Are you a Chromo Inc Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Chromo Inc Tablets & eReaders
Most Popular Question
forgot pin unable access
  • Tablets & eReaders
