20 Most Recent Cannon EOS Rebel XT 8 Megapixel Digital SLR Camera Body Only - 18 mm - 55 mm - Black 1.8" LCD - 3.1x Optical Zoom - 3456 x 2304 Image - PictBridge Questions & Answers
How do i take a photo with the cannon if the screen is black
Try the following steps when the lens is stuck and will not open, retract, or extend.
  1. Turn the power off, eject the battery pack, and reinsert it into the camera.
  2. Turn the power back on and check if the drive part of the lens moves properly.
  3. If the lens still will not open, retract or extend, then reset the camera.
7/24/2022 6:35:34 AM • Cannon EOS Rebel... • Answered on Jul 24, 2022
After charging the battery and the green light says its charged. I put it into my camera and it doesn't turn on
Do you have another battery you can try? The battery should be charged, must have a dead camera if that is the case.
6/4/2016 3:38:49 PM • Cannon EOS Rebel... • Answered on Jun 04, 2016
Why is cannon rebel reading busy trying to load photo's to computer?
Check for bent or broken CF pins. This model also has a screw that always comes loose and may have shorted out part of the main circuit. Neither of these problems are consumer repairable, and I would suggest you seek a local repair shop.
11/4/2014 5:07:21 PM • Cannon EOS Rebel... • Answered on Nov 04, 2014
HOW TO FIT A CANNON TIMER TO A MODEL 10305G
All questions need full 'make model (what it is)' as first 3 words please You posted to Cannon Cameras. There are 10,000 categories to choose from, Cannon Camera or Cannon Cooker? https://www.google.com/search?q=Cannon+10305G+fit+timer No one has documented that, but on my cooker there are screws on the sides of the top rail and two screws at the back. Then you can remove the front display panel and get access to the clock and timer. https://www.google.com/search?q=Cannon+10305G+fit+timer ..
8/31/2023 4:16:01 PM • Cannon Cameras • Answered on Aug 31, 2023
PowerShot SX530 won't playback movies, and blinking green light
There are a few things you can try to resolve the issue with your PowerShot SX530 not playing back movies and the blinking green light:
  1. Reset the camera: Try resetting the camera to its default settings. To do this, go to the menu and look for "Reset All" or "Reset to Default" option. Follow the prompts to complete the reset.
  2. Check the memory card: Ensure that the memory card is inserted properly and that it is not full. If the memory card is full, the camera may not be able to play back movies. You can also try using a different memory card to see if the issue persists.
  3. Charge the battery: If the battery is low, it may cause the camera to behave erratically. Charge the battery fully and try using the camera again.
  4. Update the firmware: Check if there are any firmware updates available for your camera model. Visit the Canon website and download the latest firmware version. Follow the instructions to install the firmware on your camera.
If none of the above steps work, it's possible that there may be a hardware issue with the camera. Since your camera is still under warranty, I would recommend contacting Canon tech support for assistance. They may be able to help you diagnose the issue and provide a solution.
3/3/2023 4:32:39 AM • Cannon Cameras • Answered on Mar 03, 2023
Cannon sx160 is, says ISO start tracking AF, what does this mean?
AF, in this context, refers to autofocus. Using the autofocus function of a camera, you're allowing the focus motor to adjust to change focus instead of manually moving it yourself. When working in the autofocus setting, you can also often select the focusing mode as well.
7/24/2022 2:30:19 PM • Cannon Cameras • Answered on Jul 24, 2022
What card is needed in camera never used new startup
CFexpress or XQD card. However, Compact Flash, microSD and CFast cards are still all regularly used as well.
7/24/2022 2:24:29 PM • Cannon Cameras • Answered on Jul 24, 2022
2answers
Cannon iP110 white light flashing and i cant turn the power off to re set
When the Power lamp flashes green even though the printer is not in use, the printer is shaking the ink tanks. It takes about 10 seconds to 2 minutes. A printer problem has occurred. Disconnect the printer cable from the printer, turn the printer off, and then unplug the printer from the power supply.
7/24/2022 12:10:43 PM • Cannon Cameras • Answered on Jul 24, 2022
2answers
Camera model: Canon power shot
Usually a stuck lens is caused by dirt getting into the gap between the lens barrel sections. The simplest thing to try is a freshly recharged battery, which might just have the power to overcome the resistance. Plugging in an AV cable sometimes blanks the screen, leaving just a bit more battery power for the lens.
7/24/2022 12:08:38 PM • Cannon Cameras • Answered on Jul 24, 2022
2answers
Need to upload photos from my computer back onto my cannon digital camera
To upload your photographs using a USB cable, follow these steps:
  1. Plug the correct end of the USB cable into the corresponding USB slot on your Canon camera.
  2. Plug the fitting end of the USB cable into its correlating USB slot, either on the side of your laptop or on your computer tower.
  3. Turn on your digital Canon Camera and wait for your computer screen to provide you with prompts.
  4. Follow the directions on your screen to upload the photographs into your corresponding photography viewing software. This software can differ whether you have a Mac OS or Windows PC.
7/24/2022 11:59:04 AM • Cannon Cameras • Answered on Jul 24, 2022
I have a Cannon Coolpix 1840 Camera with lens error message. I tried turning it off and on and changing batteries. What else can I do?
  1. Remove the batteries and wait a few minutes.
  2. Try pressing and holding the Menu, Function, Function Set, or OK while turning on the camera, or otherwise find a "factory reset" option.
  3. Try turning the camera on without a memory card inserted.
7/24/2022 9:52:24 AM • Cannon Cameras • Answered on Jul 24, 2022
I'm having trouble with my cannon n series lens closing help
7/24/2022 9:40:46 AM • Cannon Cameras • Answered on Jul 24, 2022
How to reset my cannon speedlight
Cameras with a RESET button
  1. Locate the RESET button on the camera.
  2. Using pointed object (like a ballpoint pen), press and hold the RESET button for 2-3 seconds.
  3. Release the RESET button.
7/24/2022 9:37:54 AM • Cannon Cameras • Answered on Jul 24, 2022
How do I erase "saved"images on Cannon PowerShot A3100IS
In the camera's playback mode, select the image you wish to erase using the or buttons and press the button. A confirmation screen appears. 2. Confirm that [Erase] is selected and press the button to confirm erasure of the image.
7/24/2022 6:54:21 AM • Cannon Cameras • Answered on Jul 24, 2022
I have a cannon sx160is . When I power on the camera the lens comes out but the screen is black. When I turn the camera off the lens doesn't go all the way back in.
7/24/2022 6:34:29 AM • Cannon Cameras • Answered on Jul 24, 2022
Camera won't come on when it does it says to change batteries and their new batteries. It also say no image. What do I need to do?
What's more likely to be the issue is that the spring loading on the door has loosened over time, and the battery simply isn't being pressed up against the contacts in the camera firmly enough. I had this issue with my S90. I found the "spring" in the door (there are two metal plates, the one beneath, that's up against the plastic is the "spring"), and did a partial disassembly and bent the spring plate a little bit to make it push the contact plate against the battery more strongly. Trying this, or adding a few layers of paper below the contact plate might work for you to eliminate the issue.
7/24/2022 6:22:15 AM • Cannon Cameras • Answered on Jul 24, 2022
The lens won't open when I put the camera on. It's a Cannon Power Shot SX720 HS
Malfunctioning lens mechanism - service, repair or replace.
12/24/2019 5:36:32 PM • Cannon Cameras • Answered on Dec 24, 2019
How do I retrieve pictures from my memory card in my cannon a460
You should have a USB cable that lets the camera act as a reader, If not go out and purchase a memory card reader to view and transfer the image to your computer. you can also just buy a micro USB cable to stick in the camera if you lost yours. But an SD card reader will be your better option.
9/28/2019 4:47:40 PM • Cannon Cameras • Answered on Sep 28, 2019
Cannon power shot 3500 is lens is cracked
8/18/2019 3:13:35 AM • Cannon Cameras • Answered on Aug 18, 2019
2answers
My cannon power shot camera wont read my sd card
Does it read when plugged into a computer?
6/17/2019 6:07:46 AM • Cannon Cameras • Answered on Jun 17, 2019
Cannon EOS Rebel XT 8 Megapixel Digital SLR Camera Body Only - 18 mm - 55 mm - Black 1.8" LCD - 3.1x Optical Zoom - 3456 x 2304 Image - PictBridge Logo
3 questions posted
Top Cannon Cameras Experts
ZJ Limited
ZJ Limited
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Cannon Camera Expert? Answer questions, earn points and help others
View Most Popular
Cannon Cameras
  • Cannon Cameras
Most Popular Question
photo cannon screen black
  • Cameras
