20 Most Recent
Cannon AC Adapter Questions & Answers
How to download cannon service tool?
The Canon Service Tool is a software program used to reset or clear error messages on certain Canon printers. It is a proprietary software and can only be obtained through official Canon channels. Here are the steps to download the Canon Service Tool:
- Go to the Canon website and search for the service tool specific to your printer model.
- Click on the link to download the service tool.
- If prompted, enter the serial number of your printer to verify that it is compatible with the service tool.
- Follow the instructions provided to download and install the service tool on your computer.
It is important to note that the Canon Service Tool is a specialized tool and should only be used by trained professionals who have experience in servicing Canon printers. Using the tool improperly can cause damage to the printer or void its warranty. If you are not a trained professional, it is best to contact Canon customer support or take the printer to a certified technician for service.
Cannon Micro Printer 50 will not show the entire display, do you know what this could be?
If the Cannon Micro Printer 50 is not showing the entire display, there are a few things that could be causing the issue:
- Screen settings: Check the screen settings to make sure they are set correctly. Adjusting the brightness, contrast, and screen size settings may help fix the problem.
- Low battery: The issue could be due to a low battery. Make sure the printer has a fully charged battery and try turning it on again.
- Loose or damaged cable: Check the cable connecting the printer to the computer or power source. If the cable is loose or damaged, it could be causing the issue.
- Software issues: There could be a software issue causing the problem. Try updating the printer's software or reinstalling the driver.
- Hardware issues: There may be a problem with the printer's hardware. If the above steps do not resolve the issue, you may need to contact Canon customer support or take the printer to a technician for further troubleshooting.
In any case, it is best to refer to the user manual or contact Canon customer support for specific instructions on how to troubleshoot and fix the issue.
I have a cannon MP237 and I am trying to copy something. The scanner only goes half way and stops and then the orange light comes on. This all started from a jammed piece of paper.
It is possible that there is still a small piece of paper stuck inside the printer that is causing the issue. Here are some steps you can take to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Open the printer cover and remove the ink cartridges and any paper that is visible.
- Look inside the printer for any small pieces of paper or debris that may be causing the issue.
- Use a pair of tweezers or a flashlight to carefully inspect the inside of the printer for any foreign objects that may be causing the problem.
- Once you have removed any debris, close the printer cover and reinsert the ink cartridges.
- Plug the printer back into the power source and turn it on.
- Try to make a copy again to see if the issue has been resolved.
If the problem persists, you may need to contact Canon customer support or take the printer to a technician for further troubleshooting.
How to remove Error 5B for cannon IP2772 Printer without any software
Error 5B is a common error that occurs in Canon IP2772 printers when there is an issue with the printer's ink cartridges. Here are some steps to try to resolve the issue without any software:
- Remove all the ink cartridges from the printer.
- Use a clean, lint-free cloth to clean the metal contacts on the ink cartridges.
- Check the ink cartridges for any damage or leaks. If you find any issues, replace the cartridges with new ones.
- Reinsert the ink cartridges into the printer and make sure they are properly seated.
- Print a test page to check if the error has been resolved.
If the error persists, you may need to contact Canon customer support or take the printer to a technician for further troubleshooting.
I need help with my G7000 Cannon printer and do not understand the on-line manual. How do I change from the rear paper feed to the front paper cassette?
I'm sorry to hear that you're having trouble with your Canon G7000 printer. Here are the steps to change the paper source from the rear paper feed to the front paper cassette:
- Make sure that the printer is turned on.
- Open the paper output tray and the front cover.
- Slide out the paper cassette located at the bottom of the printer.
- Press the release button on the back of the printer and pull out the paper support.
- Slide the paper guides on the cassette to match the size of the paper you're using.
- Load the paper into the cassette with the print side facing down and the top edge going in first.
- Insert the cassette back into the printer until it clicks into place.
- Close the front cover and the paper output tray.
Once you've completed these steps, your printer should automatically detect the paper cassette as the paper source. If you want to switch back to the rear paper feed, simply repeat the process but select the rear paper feed option instead.
I hope this helps! If you continue to have issues, please let me know and I'll try my best to assist you further.
Cannon iR7200errorcode238 expline
The paper jam error code for the Cannon iR7200 is 238. It indicates that there is paper stuck in the printer's paper feed route. Open the front access panel gently and take out the pieces of jammed paper to clear the paper jam. Look for any pieces of paper that may have become stuck in the paper feed channel and take them out. Before attempting to unclog the paper jam, unplug the power cord.
My feeder does not work. It is a Cannon Imagerunner 330S. Serial plate XSC24741.Can this part be purchased?
The Cannon Imagerunner 330S has been discontinued for over 20 years, so it may be difficult to find a replacement feeder for it. I recommend contacting Canon's customer support to see if they have any parts or suggestions for repairing the feeder. You can also try checking with local repair shops to see if they have any compatible parts available. Contact information for Canon's customer support can be found on their website.
Cannon Oce 650 error code 16502/printer on start up. How to fix?
Check to make sure there isn't something blocking the paper output on the back of the computer. If not, open up the front door, about the top drawer, and close it. Go the back and open up the rear cover and close it. That may reset the problem. Remove ALL jobs from the queue and clear the set memory.
If that doesn't fix it, there may be a problem with the output sensor. These sensors may not be easily available on any website, so it's best to call you local Oce/Canon dealer for service.
