20 Most Recent Hisense LTDN50K360GUS 50" LED TV 1920x1080, 120 Hz, HDTV Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Hisense... | Answered on Feb 03, 2016
Using the Hisense remote, enter setup menu fpor TV. Choose SAT/Cable as signal source.
Hisense... | Answered on Feb 22, 2015
Sounds like either the CCFL tube (like a mini florescent tube) or the inverter that powers it has blown.
Hisense... | Answered on Sep 07, 2014
Do a hard reset to this set, and then check. Its remote control too be faulty. Check it first. Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Hisense... | Answered on Feb 12, 2020
Main system control IC fault. Contact any service technician. This type of fault can'n be rectified by a user. If you wish to get some details; check the site linked here. Pull up older posts. . http://electronicshelponline.blogspot.com/
buttons on side or bottom have to scroll
Hisense... | Answered on Jan 28, 2020
If you did not have this problem before it was moved, the vibration of it being moved may have caused something to come loose. You MUST transport a large flat screen unit like that in a VERTICAL position because the screen will bounce like a trampoline and it breaks. You will have to take the television apart and check all the connections to be sure they are good.
Hisense... | Answered on Jan 24, 2020
You need to check and see if there is a firmware update that might have additional apps. Some televisions dont allow it. You did not post the model number so there is no other information
Hisense... | Answered on Jan 22, 2020
THEN DON'T DO YOU TUBE ON IT SIMPLE SOLUTION
Hisense... | Answered on Jan 20, 2020
BEING THAT WE ARE NOT AN ACTUAL REPAIR SHOP WE DO NOT GUESS
Hisense... | Answered on Jan 15, 2020
Hisense LTDN50K360GUS 50" LED TV 1920x1080, 120 Hz, HDTV Logo
4 questions posted
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
tv froze while watching movies use
  • Televison & Video
