20 Most Recent Pioneer KEH-P6600 Cassette Player Questions & Answers
Cassete players do not have Aux Inputs.
You will need to use an FM Modulator type Aux device that will broadcast to a radio station preset on your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Pioneer... | Answered on Mar 22, 2015
You may download the installation manual here.
Pioneer... | Answered on Dec 07, 2012
You can download and print the instruction manual for Pioneer KEH P-6200 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Pioneer... | Answered on Feb 21, 2011
Well the major issue is the not starting as the corrosion from sitting just make the tape player not work. You can always try a tape cleaning head unit for that.
Distributor cap and rotor would be the first thing to check. If alot of buildup is in them also replace the coils as lack of spark will cause it not to fire but if its not turning over try putting into neutral and try starting.
Pioneer... | Answered on Apr 29, 2010
to install this unit in your car........as a beginner i would strongly recommend buying a aftermarket radio harness (this harness will attach to the wire plug in your factory deck simply unhook the factory player and attach this harness to the plug you just pulled out of the factory unit) once this harness is installed on the factory plug it will be a simple colour match (just attach wires to pioneer wires IE. red - red, white - white........once all the wires are attached install in dash recommend buying a mounting unit for this net part it will hold the deck in place in your dash...........after that is done install your pioneer unit push it in place apply power by turning car on..........pioneer deck should turn on and work if it does not turn right on look for a source button on the pioneer unit and hold it down till the unit turns on
good luck
hope i was able to help
Pioneer... | Answered on Mar 05, 2009
La unidad tiene disco adentro!Si es asi probablemente el laser necesita limpieza puedes comprar un disco para limpiarlo o abrir el aparato y con un cotonete con alcohol isopropilico limpiar el laser,si no funciona el laser esta dañado.
Pioneer... | Answered on Mar 17, 2008
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Pioneer... | Answered on Jul 01, 2007
Request the manual from Pioneer.
Pioneer Car... | Answered on Nov 24, 2020
Hi Mark, please download from pioneer website, or put in a search on google for this models user manual.
cheers.
Pioneer Car... | Answered on Mar 30, 2020
Pioneer KEH-P6600 Cassette Player Logo
14 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
connect aux source e g mp3
  • Car Audio & Video
