20 Most Recent ACCUTIME WATCH CORP. Frenzy Ladies Watch with Peace Sign Dial and Rainbow Band - Questions & Answers
No simple fix, you will need a watch repair shop to fix this, but make sure you get a repair estimate, it may shock you.
ACCUTIME WATCH... | Answered on Jul 14, 2016
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Watches | Answered 3 days ago
Contact Time Track Services directly and explain the problem to them. They will be able to help you sort another form of payment. They will also appreciate you took the time and effort to warn them.
Watches | Answered on Oct 19, 2020
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Watches | Answered on Oct 18, 2020
First, reset the clock to 0:00 hours. The instant the clicking stops, pop out the battery. The second hand stem should be at 0:00 hours. The front cover can only be removed from the bottom. Put both thumbs at the bottom of the font cover and push inward, but not too forcefully (Junghans stopped selling replacement covers shortly after dropping the product line and they are nearly impossible to find). The center should lift up enough to slide a thin credit/promotion/gift card under the center tab on the bottom. Then work the card up either slide to disengage the other four tabs. The five tabs are located at the bottom center, one each on both straight sides alligned with the top of the digital display, one at 7.5 minutes, and the last one at 52.5 minutes. That is easy part. Now comes the hard one You then need to glue the second hand back onto its stem. Superglue (cyanoacrylate based) works best. The second hand must be attached perfectly level or it could scrape the cover, the clock face, and the other hands as it rotates on a tilt. Practice a few times before applying the glue. You will notice that the socket on the second hand fits the stem very loosely. Once you are ready to glue, apply one drop of superglue on the second hand socket and mount it on the centermost stem and hold it perfectly still and in proper alignment and steady for a minute or so for the glue to set. Once the glue dries, put the battery in and let it run long enough to determine if the second hand is in correct alignment. Remove the battery again. Make certain the clock face is completely free of dust and dirt before reattachment of the cover. Insert the cover from the top down snapping the five tabs into place. It may be necessary to reverse the removal process. Then you can reinsert the battery. The process worked for me when mine was accidentally knocked onto the carpet and the second hand was detached from the force of the impact. In fact, I can no longer tell which one I performed the repair on.
Watches | Answered on Sep 27, 2020
Visit the website.. You will find the instructions
Watches | Answered on Sep 24, 2020
I need the manual for Invicta Reserve 6207
Watches | Answered on Sep 13, 2020
This suggests one of three alternatives are at play: 1) You don't have the manual to the watch and thus don't know the sequence to turn off the alarm n chime; 2) You have the manual and it is inaccurate. 3) The watch is defective.
https://www.amazon.com/ask/questions/Tx3VS2PTPQUSRAG/
Watches | Answered on Aug 24, 2020
Need more detail. Model number. This should go from 4.5K to 6K EUR
Watches | Answered on Jul 20, 2020
Tip
Finding replacement battery for watch (DIY).
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help.
on Jul 09, 2020 | Watches
ACCUTIME WATCH CORP. Frenzy Ladies Watch with Peace Sign Dial and Rainbow Band - Logo
1 questions posted
Top ACCUTIME WATCH CORP. Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you an ACCUTIME WATCH CORP. Watch Expert? Answer questions, earn points and help others
View Most Popular
  • ACCUTIME WATCH CORP. Watches
Most Popular Question
frenzy watch frzk1103 light up function
  • Watches
