20 Most Recent Vizio 50-Inch LED Smart HDTV 1080p Full HD 120Hz - E500i-B Questions & Answers
LCD TV-Vizio e500-bi backlight intermittent
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
7/15/2016 4:10:22 AM • Vizio 50-Inch... • Answered on Jul 15, 2016
Oder new remote and they said that it did not need to be programmed. It was order for that tv. wil not work. Help.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily..... http://electro-medical.blogspot.com/
4/28/2016 2:03:52 AM • Vizio 50-Inch... • Answered on Apr 28, 2016
We get a message on the screen when connected to the cable box, that the screen " does not support the resolution", and we get no picture.
How are you connecting it to the television? What is the box make and model that you are connecting it to?
2/18/2016 12:39:23 AM • Vizio 50-Inch... • Answered on Feb 18, 2016
Where can I download a manual?
Try here www.vizio.com/documents/downloads/hdtv/E500iB1/UM_E500iB1.pdf
2/14/2016 11:40:34 PM • Vizio 50-Inch... • Answered on Feb 14, 2016
Hi my problem with my vizio tv is that i there is no picture or sound.i tried turning off/on but nothing happens
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1/11/2016 4:32:38 AM • Vizio 50-Inch... • Answered on Jan 11, 2016
My vizio will not turn on. The light on the bottom flashes on and off, but nothing on the screen. I replaced the main board. It worked for several days then went right back this issue.
Have just looked on you tube , I typed in fix for VIZIO E500i -B1 power off and a 2.24 minute video appeared . if that does not solve your problem type the product info and fault again and check the videos that pop up . hope this info is of use to you....
12/20/2015 11:41:53 PM • Vizio 50-Inch... • Answered on Dec 20, 2015
Vizio e500i-b1 wont turn on. which part needs to be replaced
Switch or fuse
12/4/2015 11:14:37 PM • Vizio 50-Inch... • Answered on Dec 04, 2015
Does the fire stick with with this
Yes. It has. Take care.
9/24/2015 2:49:06 PM • Vizio 50-Inch... • Answered on Sep 24, 2015
Why can't I connect to wireless?
you need a type G or above router that has the wps trigger button or a type G wimen that can allow you smart TV to connect to the right protocals its all a matter to the TV whats avalible on the wifi router if you have a GH modem then look to upgrade
11/30/2014 4:11:57 PM • Vizio 50-Inch... • Answered on Nov 30, 2014
Remote code vizio 50 inch smart tv
0840.0924. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
8/11/2014 4:54:22 AM • Vizio 50-Inch... • Answered on Aug 11, 2014
999999 keeps on popping up on the top right corner and i dont know how to fixit
use remote, and try to change channel manually, IF using a all in one type ( not one that came with tv ) could be a problem, try another universal remote..if no good, call tv manuf.
6/27/2014 12:15:51 PM • Vizio 50-Inch... • Answered on Jun 27, 2014
Vizio M557-G0 Part Number 10248401223; Serial Number LAFAQCMV No Power
This is explains the problems you face. In the case of Visio, it is time for a new set. https://www.fixya.com/support/r29790007-repairing_own_television ..
1/25/2022 1:34:44 AM • Vizio Televison... • Answered 3 days ago
Vizio E420-A0 starts to power on, flickers, powers off
As long as you're getting the standby lamp you will see the standby voltage like you have. Vizio didn't really have issues with caps although I can't say Ive never had any bad. As far as backlights, you can see them through the back of the set with the back off but even if they're not working chances are that's not your issue as Vizio has local dimming and generally they don't all fail so I don't think backlights is your issue. I would suspect main board issues, to be more exact I think your EEPROM has bad data, it's an IC you can change if you have experience in soldering small devices as a new IC can be purchased for about $15, easy way to fix would be replace the main board and they aren't all that expensive in this model...below is a listing for one from shopjimmy, by far the best place to get boards...I wouldn't buy from ebay as in a lot of cases the boards are bad
1/19/2022 5:20:49 PM • Vizio Televison... • Answered on Jan 19, 2022
My vizio tv m55-c2 has a ghosting menu picture on top one third of the screen, what can i do to fix my self
Try replacing the tcon board, if that doesn't fix it you have a bad panel and it's not fixable
1/17/2022 7:07:00 PM • Vizio Televison... • Answered on Jan 17, 2022
How do I get to it sensor on a vizio television
Removing the back allows access to everything.
1/14/2022 11:56:29 PM • Vizio Televison... • Answered on Jan 14, 2022
2answers
Code for Vizio tv e500ar on a universal Phillips remote control
Nobody buys universal remotes these days, they are so 1980. You buy a Facsimile Remote, an exact copy of the original. replacement remotes https://www.google.com/search?q=Vizio+tv+e500ar+replacement+remote There are far TOOOO many codes for Vizio! https://codesforuniversalremotes.com/remote-control-codes-vizio-tvs/ ..
1/14/2022 2:01:27 PM • Vizio Televison... • Answered on Jan 14, 2022
Vizio 50-Inch LED Smart HDTV 1080p Full HD 120Hz - E500i-B Logo
17 questions posted
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
need print out manual
  • Televison & Video
