20 Most Recent Bernina Artista 640E Sewing, Quilting and Embroidery Machine with Embroidery Module Questions & Answers
What is your question? Can it be done? Yes, but you'll probably want a Bernina tech to do it if the part can be found.
Bernina Artista... | Answered on Dec 10, 2016
Assuming you have threaded the bobbin case correctly, you might try using a different bobbin. There may be something wrong with it. Make sure that there is no thread sticking out of the side of the bobbin.
If there is a bobbin thread sensor, it could be dirty causing it to not read the bobbin correctly.
When you thread the upper thread, be sure to ALWAYS RAISE the presser foot so the tension disk is released and the thread can seat properly.
Bernina Artista... | Answered on Oct 11, 2016
You should probably take it to a Bernina repair person.
https://www.youtube.com/watch?v=RHYwvv8lJ74
http://sewsabina.com/blog/?p=84
http://freemo.com/bernina-artista-730e/
Bernina Artista... | Answered on Jun 23, 2016
May be best to contact your Bernina dealer.
Bernina Artista... | Answered on Feb 09, 2016
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
sounds like the computer is having trouble responding to the commands it's given, may need to be serviced.
Bernina Artista... | Answered on Jun 05, 2015
it's possible there could be something wrong with the computer, only a sewing machine repair shop can tell you for sure
Bernina Artista... | Answered on Jun 03, 2015
You obviously have a faulty machine take it back to your dealer where you bought or directly contact Bernina.
Best wishes.
Bernina Artista... | Answered on Nov 26, 2014
Service manuals are difficult to find for most sewing machines, which Bernina is not an exception. However, there is a Yahoo Group called "BerninaThirtySomethings" that has conversations, documents, photos, etc. for the vintage Berninas including the 730 Record. You can join the group (must have a Yahoo email account) and download a variety of documents including a "Setting Manual" for the 730.
Yahoo Groups
http://www.thesewingforum.co.uk/showthread.php?t=28999
Bernina Sewing... | Answered on Sep 20, 2020
Your service engineer will know how to reset it.
Bernina Sewing... | Answered on Sep 11, 2020
3 years! All the old oil and fluff has congealed. It needs a full clean, lubrication service and timing check.
Bernina Sewing... | Answered on Sep 06, 2020
The start on button could be broken or the sewing machine powers supply could be staring to going bad.
Bernina Sewing... | Answered on Sep 05, 2020
Make certain the stitch length is not set to 0 or neutral.
Bernina Sewing... | Answered on Aug 11, 2020
sorry no clue my lever has to be down to sew always
Bernina Sewing... | Answered on Jul 27, 2020
how can we know what needs fixing if you don't tell us! ??
Here are few things that might need fixing with solutions and videos. If it is a tensioning issue, click COMMENT to expand the issue
https://www.google.com/search?q=Bernina+880+error+1100-+how+to+fix
Bernina Sewing... | Answered on Jul 21, 2020
The needle must begin to rise and create a tiny bulge of top thread and clear the hook as the hook captures the top thread.
Remove needle plate so you have clear view hook and needle. Rotate handwheel until needle reaches bottom of stroke and just begins upward. The hook needs to be right there but not too early and hit the needle. If too late the hook will not capture the thread causing a dropped stitch.
If the last thread bunching didnt cause a shaft slip you should be able to advance or retard the hook by 1 belt notch and get it back in time otherwise you'll need to loosen a shaft coupling screw to fine tune timing.
Search for videos on adjusting timing.
Bernina Sewing... | Answered on Jul 17, 2020
Bernina Artista 640E Sewing, Quilting and Embroidery Machine with Embroidery Module Logo
11 questions posted
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bernina Sewing Machines
Most Popular Question
bernina 640 will sew 4 5 stitches stop
  • Sewing Machines
