20 Most Recent Juki 2-Needle Overlock Machine MO-734DE Questions & Answers
My bobbin winder on my Juki TL 2000qi will not work. Everything else works, just not the bobbin winder. What can I do? Brand new, out of the box
Read the manual twice. If it still doesn't work, contact the seller as it is under warranty. It appears to be a known issue if the bobbins are sourced from China. The bobbins are special. See the video instructions. https://www.google.com/search?q=Juki+TL+2000qi+wind+bobbins ..
1/11/2022 3:04:41 AM • Juki Sewing... • Answered on Jan 11, 2022
2answers
I need juki hzl 009 manual
https://www.juki.co.jp/household_en/hsm/pdf/f-series_en1209.pdfPossible to find other manuals at https://www.juki.co.jphttps://global.rakuten.com/en/store/andomishin/item/20130314/ https://global.rakuten.com/en/store/andomishin/item/20130314
1/2/2022 7:15:43 AM • Juki Sewing... • Answered on Jan 02, 2022
Juki 210d error 3
Hi about error 3 please make sure first dc voltage comining fro power board to servo board check J8,J28, second encoder signal from the motor is not supplied check J2,J29, third check connection between main board and servo board J11,J1 best regards ashraf
12/20/2021 3:48:11 AM • Juki Sewing... • Answered on Dec 20, 2021
How can I solve the problem of E3 on my Juki industrial sewing machine?
Hi can you please send more information ? machine model and control box model. best regards ashraf [email protected]
12/20/2021 3:40:36 AM • Juki Sewing... • Answered on Dec 20, 2021
Juki TL 2010Q stopped sewing new out of box
Question moved from Cars and Trucks to Juki Sewing Machine. I wonder if you mean 'sewing' rather than 'seeing'?? If it is new, did you read all the manual? Did you make sure the leads are nice and tight. It is under warranty, contact seller or maker. ..
12/19/2021 12:03:03 AM • Juki Sewing... • Answered on Dec 19, 2021
2answers
Juki HZL-F series bottom bobbin thread is not picked up and will not sew when start button is pushed.
Try a brand new needle. If that doesn't work, most likely the machine is out of time. ...
11/27/2021 4:42:55 PM • Juki Sewing... • Answered on Nov 27, 2021
4answers
Juki MO2300 Manual book
Search for: Make Model manual
11/16/2021 9:15:16 AM • Juki Sewing... • Answered on Nov 16, 2021
0answers
My hand wheel is locked after a needle broke inside my machine. How do I fix this?
The broken needle may be jammed in the hook or race and/or the hook or race may be damaged. Remove the bobbin and the hook. See video on removing hook on a Juki.https://youtu.be/GqWBdQ4bLrk
10/10/2021 8:57:48 PM • Juki Sewing... • Answered on Oct 10, 2021
Juki HZL-29Z not stitching!
Question edited for clarity, spelling and capitalization. Question moved from category 'Cars and Trucks', to Juki sewing machine. When was the machine last serviced? They should be serviced every 2 or 3 years. Most people never service until they fail and then wonder why they failed. Slow, weak sewing would be caused by the foot pedal having dirty contacts n the insides. It has a wire wound track and a contact terminal. The fact the needle doesn't go up and down is either caused by it being in bobbin winding mode, or a link has come off inside. So first thing to do is open up the foot pedal and clean the contacts with electrical switch cleaner (NOT WD40). Then check you aren't in Bobbin winding mode, normally a clutch on the hand wheel. Or Take it to Juki Service. Videos and the Service Manual in the link https://www.google.com/search?q=Juki+HZL+29+Service ..
10/4/2021 5:53:22 PM • Juki Sewing... • Answered on Oct 04, 2021
My Juki HZL-F300 is making a clicking noise in the hand crank area, is this normal for this model? It's brand new.
Sewing machines can make clicking noises, but as yours is new, I would take it to the seller and ask them to check it.
9/16/2021 4:58:53 PM • Juki Sewing... • Answered on Sep 16, 2021
2answers
Juki e code 808 solulation ddl8700-7
hello regarding error code E808 mostly happened in SC-920 control: 1- check +33 DC volt output for thread trimmer - bac-ktack- presser foot lifter. 2- check CTL board. ( any electronic components damage ) the most reason for E808 coming from CTL board. best regards ASHRAF ABOZID [email protected] Cairo - Egypt
8/24/2021 8:24:52 PM • Juki Sewing... • Answered on Aug 24, 2021
I keep having a black substance building up on the screw that holds the needle in place on my Juki 2000 which then gets on my fabric and is near to impossible to get off.
Is there excessive oil on the needle shaft (above the screw)?
Try lowering presser foot and advance hand wheel so needle is at its lowest position. Then take a clean dry rag and wipe around the shaft just above the screw and see it gets dirty. If yes, the machine needs a thorough clean and lube.
8/16/2021 9:55:51 PM • Juki Sewing... • Answered on Aug 16, 2021
I have juki 8500-7 automatics sewing machine now the foot lifter not working please help me out
sadly only a person that can see it can help . we have no crystal ball here
5/23/2021 11:21:26 AM • Juki Sewing... • Answered on May 23, 2021
What tool do I need to change the needles on a juki mo-816 ff6?
open eyes and look at the screw
5/22/2021 5:55:34 PM • Juki Sewing... • Answered on May 22, 2021
Juki 2-Needle Overlock Machine MO-734DE Logo
1 questions posted
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Richard
Richard
Level 1 Expert
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
machine not sewing correctly just
  • Sewing Machines
