20 Most Recent Samsung PN60F5300BFXZA 60" 1080p 600Hz Plasma HDTV Questions & Answers
2answers
I have a Samsung model PN60F5300BF that just died on me. Its barely 2 years old and one day it just went dead as if there is no power to the TV, even the red indicator light does not come on anymore
This may seem silly but you shuold check to be sire the power cable is plugged into the back of the TV, the other end is in a power receptacle, and if it's in a power strip, that that strip it turned on (some have a switch). A breaker might have tripped too. If none of these are correct, see if there's a reset button on the rear of your TV.
12/7/2016 6:11:49 AM • Samsung... • Answered on Dec 07, 2016
Samsung 60 inch plasma tv
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/15/2016 5:54:46 PM • Samsung... • Answered on Jul 15, 2016
How do I get rid of horizontal lines that ghost the image on my screen?
The t con board or the LCD panels is faulty. Can confirm only by replacing the Tcon board. If you wish to know more about Tcon board problems and troubleshooting then check the following link. http://electro-medical.blogspot.com/
10/3/2016 3:43:54 PM • Samsung LA... • Answered on Oct 03, 2016
How do I fix my webcam?
Reload or update the driver from the manufacturers website!
12/5/2014 5:30:33 PM • Samsung LA... • Answered on Dec 05, 2014
Our picture suddenly changed drastically from a clear sharp picture to a blurry, faded looking picture. Some colors are extremely bright, others are faded out. It is so bad it is not viewable.
Please check the flat cable connections between TCON board and the LCD panel. If this is ok, then it is either the TCON board or the LCD panel itself. Good luck.
1/9/2014 1:48:39 AM • Samsung LA... • Answered on Jan 09, 2014
0answers
0answers
Fix backlight on la40s581b
Check and replace the backlight inverter board. Do not think that it works only with some capacitors. The inverter transformers are the main component on that board, and always gets shorted inside, and is irrepariable.
2/25/2013 10:03:09 AM • Samsung LA... • Answered on Feb 25, 2013
Samsung PN60F5300BFXZA 60" 1080p 600Hz Plasma HDTV Logo
4 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LA Samsung
  • LA Samsung
Most Popular Question
samsung 60 inch plasma tv
  • Televison & Video
