20 Most Recent Nor-Lake KLB810CL Questions & Answers
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Nor-Lake... | Answered on Jan 26, 2012
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Nor-Lake... | Answered on May 29, 2009
It's not unusual for a refrigerator to drip a little water on the floor after you replace the water filter-air trapped in the water dispenser system can make the water dispenser drip enough to overflow the drip tray below the dispenser. You can fix it by streaming a gallon or two of water through the dispenser to eliminate the trapped air.
If water drips on the floor from the back of the refrigerator, a leaking water inlet valve or cracked water system tubing could be the cause. A clogged or cracked defrost drain tube could also cause the leak. Defrost condensate water collects in the drain pan at the bottom of the refrigerator so a cracked or overflowing drain pan can also cause water to drip on the floor behind the refrigerator. Check the drain pan for cracks and clean out any foreign objects that may be inside the drain pan.
Excessive frost caused by a leaking door seal can also cause the defrost drain pan to overflow. Check the door gaskets and replace them if damaged.
Refrigerators | Answered Yesterday
Try cleaning the coils and make certain the filter is clean. If that doesn't work your unit may be low on Freon.
Refrigerators | Answered 2 days ago
CALL A LOCAL REPAIR SERVICE IT IS NO A DIYER TASK
you have an air damper motor problem call a repair shop , support the working class
Refrigerators | Answered on Jun 01, 2020
You don't and if you did in some parts of the world you would be breaking the law.
The CO detector, alarm and safety cut-off are important safety features necessary on an appliance venting combustion gas into the room space where the fridge is sited. Carbon monoxide is a colourless and odourless combustion gas that can cause illness and even *****.
If the CO detector is faulty you should get it fixed. If it isn't faulty there should be no trouble if the fridge is sited in a large well-ventilated space.
If the space is too small and ventilation is a problem, the DV suffixed fridge should have been chosen (instead of your current choice of CM) so it could vent combustion gas directly through an external wall into fresh air.
Whether or not your fridge can be converted - try contacting the manufacturer or dealer.
If it is a frost free freezer it could be the thermostat has a fault that has left the defrost heating panel switched on.
If the freezer is otherwise working correctly the refrigeration system will be trying to remove the heat from inside to the outside and so the compressor will be running continuously and the condenser will be quite hot.
If the condenser isn't hot it is likely the compressor is broken or the refrigerant has escaped...
Refrigerators | Answered on May 30, 2020
https://www.repairclinic.com/Shop-For-Parts?query=SEAL%20OF%20united%20refrigerator%20model%20ucf200%2Fc%2C
Nor-Lake KLB810CL Logo
0 questions posted
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nor-Lake Refrigerators
Most Popular Question
type refrigerant
  • Refrigerators
