20 Most Recent Liebherr CS1601 (15.5 cu. ft.) Bottom Freezer Refrigerator Questions & Answers
Why is it beeping sporadically?
It looks like it needs service of some sort. Have you referred to its manual?
6/3/2015 12:14:32 AM • Liebherr CS1601... • Answered on Jun 03, 2015
Hallo, My Leibherr premium freezer (located below
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/19/2011 3:08:14 AM • Liebherr CS1601... • Answered on Sep 19, 2011
My bottom freezer was left open probably for about
NOTE: This
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/17/2011 3:56:22 PM • Liebherr CS1601... • Answered on Sep 17, 2011
I have a Liebherr Fridge with an icemaker that
When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the icemaker won't make ice. (Also note that your home's water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn't make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn't arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn't kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism-this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you're skilled at home repairs, this job is better left in the hands of an appliance repairperson.
Check it and keep us updated.
6/29/2011 1:06:46 AM • Liebherr CS1601... • Answered on Jun 29, 2011
Liebherr cnesf 5013 superfrost always beeping
Maybe it is only in the settings, I don't know the details of your ref but I would like to suggest to consult it in the technical experts.... because you said, it is turning on and off but it is working, maybe you only mistakenly click some button but if not, the refrigerator is the problem ( if it is new one, you can return it and replace a new refrigerator but in this case, you need to check it before replacing another one)
10/29/2021 4:02:51 PM • Liebherr... • Answered on Oct 29, 2021
My Liebherr premium freezer keeps dropping temperature.
call a local repair service
6/16/2021 12:29:20 AM • Liebherr... • Answered on Jun 16, 2021
My integrated Liebherr brand new fridge/freezer is making a clicking sound? Fan? It’s not the alarm
then you have the dealer send out the tech to fix it we do not try to fix NEW things warranty work
5/29/2021 8:48:19 AM • Liebherr... • Answered on May 29, 2021
I have a Liebherr fridge CS 2062. Both doors gaskets need to be replaced. What are the part#s and where to order? Thanks
That's not the way it works. Normally you contact a company and say "I want door gaskets for a Liebherr CS 2062". Let them worry about part numbers. They are here https://www.letstalkparts.com/Liebherr-Appliance-Parts-s/283.htm https://www.google.com/search?q=Liebherr+fridge+CS+2062.+doors+gaskets ..
4/7/2021 9:01:40 PM • Liebherr... • Answered on Apr 07, 2021
Liebherr fridge stops working after 1 hour.
The Spaminator Mar 22, 2021 Hi Jasmin Black, I suspect ice build up behind the back panel of the freezer could be causing this. this could be due to a faulty thermostat transducer that tells the freezer to defrost when the ice builds up.
3/22/2021 10:25:01 AM • Liebherr... • Answered on Mar 22, 2021
Model CN4003-21. Why doesn't the refrigerator part cool?
first check the freezer compartment temperature
12/4/2020 7:32:47 PM • Liebherr... • Answered on Dec 04, 2020
Liebherr C1650 Refrigerator Ice Cube Maker Problem: making cubes but also spilling excess water.
Descale it. Clean it with a brush. check the inlet is clean. Check the drain is clear. However, it is a known issue. Advice here https://www.houzz.com/discussions/2333121/liebherr-36-icemaker-problems Page 20 http://assi.lhg.liebherr.com/Serviceline/b2b/bab2b/Media/Documents/BA/708248101_gb.pdf ..
11/29/2020 7:46:00 PM • Liebherr... • Answered on Nov 29, 2020
Why Liebherr CS 1651 freezer temperature keep flashing
snelvrieser aan of temp onder 16 gr
8/19/2020 6:21:07 PM • Liebherr... • Answered on Aug 19, 2020
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
6/25/2019 11:45:28 AM • Liebherr... • Answered on Jun 25, 2019
Liebherr CS1601 (15.5 cu. ft.) Bottom Freezer Refrigerator Logo
10 questions posted
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
bottom freezer left open probably about
  • Refrigerators
